Question about Whirlpool Dryers
My dryer Whirpool model LGR4434AQ0 don't heat air in cycle. What it can be?
    President:
  • 1,273 Answers
Hello.
Most of the time, the problem is:
1. a plugged vent system.
2. broken heating elements or
3. a bad thermostat.
To check the venting system, turn the machine on and check for a strong air flow where the dryer exits the house, outside. If there is weak or no air flow, you may have an obstruction in the ducting, at the drter, or at the louvered vent in the wall to the outside. Unplug the dryer and remove the duct. Holding it like a "U", take it outside and shake it out. Look ate the wall vent; clean as necessary. Look into the dryer exhaust, remove any debris found there. Pull the lint trap and inspect the cavity. Vacuum out any debris. Replace the ducting.
If this doesn't fix you. Check your heating elements. If you have an electrical test meter and know how to use it, gain access to your heating element terminals inside the back panel, and test for continuity. Replace any defective heating elements. They are readily available from any appliance parts supply house.
If this still doesn't solve your problem, test and/or replace the thermostat as required.
Hope this was useful to you!
--W/D--
Posted on Jul 14, 2009
I have a gas dryer that when cycle begins it heats but after a while it stops heating and it takes too long for clothes to dry...Why is this happening?
I would check the the vent hose first. It might be clogged with lint or stopped up some other way or even crimped where the air won't flow. Turn on the dryer and go outside and be sure there is a good flow of air coming out of the vent. If there's not much air flow dis connect the hose and clean it out
Dec 13, 2014 | Whirlpool WGD4800XQ Whirpool 29" Gas Dryer...
I have a dryer model mde3706ayw that is not heating up...i have replaced the heating element, thermal fuse and both the high limit and cycling thermostats and still all im getting is cool air...the timer...
Check to be sure that you have 240v at the terminal block. If you replaced all those parts, there is nothing left to check. Either you don't have 240v or one of those parts is bad.
Nov 11, 2012 | Maytag MDE3706 Electric Dryer
I own a Whirpool Special Edition 3 Cycle. It works but is not giving off heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 25, 2011 | Dryers
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer that will not dry well
One of two things... An almost totally blocked vent to the outside or a bad heating element. Remove the vent form the back of the dryer and get a "feel" for how much air flow is coming straight out without any venting connected. Then connect it back up and with the dryer running, go outside and give it the "feel test" judging as close as you can the percentage of air flow loss through the house venting. Anything more the 30% air flow loss will cause the dryer to take forever to dry. As far as the heating element, on a Whirpool, it slides up into a plenum in the back as kind of a rack type assembly. Not that difficult to replace by remove wire connecting to it, thermostats attached to it and (probably) two screws that are securing it in the plenum.
Dec 20, 2008 | Whirlpool Washing Machines
Whirpool twin thin no heat
Make sure you have 220 volts first at dryer. Heating element is on back of dryer. You'll need a test meter to see what's wrong unless you can see broken wire in element itself. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool LTE6234D Top Load Stacked...
Just another damb heating problem
on gas dryers there are two coils on the burner assy. (small black cylinder with two wire haness) one opens initially to allow gas for ignition after that the flame sensor will allow the secondary to open for continuous flame i suggest replacing them both
Jan 18, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
