Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Leaks water, underneath at the front - Whirlpool Ultimate Care II LSQ9564J Top Load Washer
  • 5,911 Answers
This problem is usually attributed to a leaking drain pump, or drain lines. To access, follow the steps in the link below:
http://www.fixya.com/support/r397094-replacing_water_pump
I would recommend filling the wash tub with a small amount of water before you shut it off and unplug the washer. The washer will not run with the external case removed and the lid switch disconnected. This will give you a small amount of water to determine where the leak may be coming from.
The drain pump is located directly under the wash tub in the front. If the pump leaks, it is not serviceable and must be replaced. You can purchase replacements on line at searspartsdirect.com or appliancepartspros.com. Check each site for the best price. If you do not wish to order on line, you can take the part number from either web site and go to your nearest appliance parts retailer. This is a common part that most stores carry in their inventory.
NOTE: On rare circumstances, the wash tub may develop cracks. Inspect the tub as well.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Jul 14, 2009
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
Feb 15, 2013 | Crane Elephant EE-3186 1 Gallon Humidifier
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Leaking water from underneath
The door connects to a round gasket called the "bellows". If it is torn, deformed or coming off water will leak underneath. Undo the 3 screws in the lower front panel and do an inspection of that area
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking underneath
Maybe its not draining completely? Have you tried opening the front panel, pulling out the white plug, putting a bucket under it, unscrewing the front of the plug and checking the filter?
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
My washer is leaking water from underneath. How can I fix this problem
Are you sure its from underneath as a lot of washers seem to be leaking underneath but its actually a blockage in the soap dispenser. Or the water pressure is too high and splashing out of the dispenser in this case make sure the m/c is level front to back.
Mar 07, 2009 | Roper RAS8244KQ Top Load Washer
Water is leaking from the underneath, at the front of the machine
The drain pump is located at the front, underneath. The drain pump has probably failed and will need to be replaced.
Jun 04, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
104 people viewed this question
Dan Webster
Dan Webster
Sal De
