SOURCE: GE Profile CF24W-PL
Make sure the fan inside the freezer is running. If so, remove the cover from the back of inside of the freezer. If it is clogged with frost you have a defrost circuit problem. Most likely the defrost heater mounted at the bottom of the evaporator coil is burned out.
Post back with any questions and let me know what you find.
Thanks/Mike
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
SOURCE: Freezer works, it's cool nolt cold in the
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
heatman101
SOURCE: Freezer works great but the
details of problem not enough,but try the following.1.locate the temperature dial( a nob with numbers indicating range of temperature and reset it to the maximum),then wait and see it there will be any change.
heatman101
