Question about Acer Aspire One Netbook 8.9" Notebook
MY SYSTEM SAYS NO BOOTABLE DEVICE--INSERT BOOT DISK
  • 36 Answers
Okay, first things first. Unplug everything except for the power cord. Make sure the floppy drive (if you have one) and CD-ROM drive are empty. Go into your computer BIOS settings and make sure that the computer is set to boot from your hard drive first. (Depending on the computer, usually holding down F2, F4, F6, F8, or even other function buttons will allow you to do this. Not all of the buttons at once, but just hold each one down when you start the computer until the BIOS comes up). If this doesn't work, your Hard Drive is either corrupted, all information has been deleted, or simply came loose over time. You may be able to fix this yourself. The easiest solution is to reformat your computer using the original disks your computer came with. You can also use a licensed copy of Windows disk.
If you have information to recover, I would look into Bart's PE Builder (google it), although that requires another computer. If you have access to another computer there are many boot disks that you can download or buy.
If none of these work, try getting your computer into DOS mode. It's much harder with XP and Vista, but Windows ME and earlier it should be an option. simply type C:\ at the prompt, cd windows, dir/w. This will tell you if windows is still there. At least then you'll know your options. If windows is gone, the only way to get it back is to reinstall it. I hope something in here helps someone.
Posted on Jul 14, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
  • 742 Answers
SOURCE: NO BOOTABLE DEVICE INSERT BOOT DISK AND PRESS KEY
Do you have your windows OD running? If so, make sure that there is NO CD or DVD Disc left in your CD/DVD Combo drive while you are turning your computer ON. Now, eject the CD or DVD and try to start your computer again.
Posted on Nov 10, 2009
  • 5 Answers
SOURCE: Acer aspire one mini notebook. NTLDR is missing..
If you don't have documents, pictures, etc on the hard drive that you need to backup, try running system recovery by doing the following (not sure if this works on the version with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
Posted on Oct 13, 2009
Godshifter
  • 13 Answers
SOURCE: Media test failure, No bootable device, insert boot disk.
That happened to me when I tried to upgrade. If you don't have an external DVD drive, you have to copy the restore disk to a flash drive, put it in the USB drive, power up, hit F12 at the first screen, move the highlight to the USB and boot from it.  Oh, and it has to be at least    1 GIG, the USB Flash drive does, or it won't fit.
Posted on May 18, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
No bootable device PXE-M0F
You need to disable booting from the device in the Bios. It will be under the Boot options menu. Uncheck it from the list of devices to boot from.
Aug 22, 2012 | Acer Aspire 9300-5349 Notebook
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
HP Pavilion dv4-1548dx no bootable device-- insert boot disk and press any key help no disk
en mi laptop hp pavili
como hago si mi laptop hp paviliondv4 sale no bootable divice -- insert boot disk and press any key
Apr 23, 2012 | Computers & Internet
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
My compaq presario c700 will not boot and it's saying that there is no bootable device, insert boot disk and press any key, however, i do not have a boot disk
Your Compaq did not detect the hard disk, that is why it is asking for a bootable device such as a boot floppy disk.
Check the BIOS configuration to see if the hard disk is detected, if not then re-seat the hard drive and boot up the Compaq again.
If it still does not boot up, then the hard disk is probably faulty.
To get the Compaq operating again, replace the faulty, install Windows operating system on the new hard drive, plus the Compaq's device drivers and your programs.
Jan 09, 2011 | Computers & Internet
My hp mini is showing Reboot and select proper boot device or insert boot media in selected boot device and press a key
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
Dec 21, 2010 | HP Mini 1000 Netbook
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Acer Aspire One Netbook 8.9" Notebook Logo
2,128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
