Question about LG WM-3677HW Front Load Washer / Dryer
I can't get the soap dispenser on my machine to open! It seems to be hung up on something. Any ideas?
  • kathyjackson Jul 14, 2009
    Figured it out! Had to take the top of the machine off and pop the clips on the top of the dispenser loose. The softner dispenser had popped up somehow. We just took it out and everything seems to be working fine now.
  • kathyjackson Jul 15, 2009
    Actually, we had take the top off and open up the dispenser from that direction. The softner portion had somehow popped up and was hanging up. We just took that part out and now there it opens. Just tugging on it only pulled the front off!
  • 92 Answers
Just give it a really good tug,it will open.
Posted on Jul 15, 2009
Soap dispenser release detergent as soon as I pour it in. Drips down int drum while pouring - before shutting dispenser. Any ideas?
check and make sure something isn't stuck that it making it stay open. maybe you need a new spring (or whatever it uses) to keep it shut.
Apr 05, 2015 | Maytag Washing Machines
Opening the soap dispenser
F02 drainage problem. what seems to be the most common problem ?
Nov 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
Sears Kenmore HE2 front load washer
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
Nov 26, 2008 | Washing Machines
Dishwasher soap not opening
These rely on mechanical timers and springs on the soap dispenser. They get a bit gunked up after a while. Don't prewash and run the the dishwasher for a few cycles with the dispenser open (put the soap tablet in the cutlery basket). If you listen to the machine you may be able to hear the click when the dispenser should open which at least tells you that it should be working
Jun 13, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
LG WM-3677HW Front Load Washer / Dryer Logo
95 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
