Question about Epson Stylus C82 InkJet Printer
PRINT I have epson c82 printer and i want my document to print only in black how can i do that ?
  • Epson Master
  • 1,113 Answers
Should be option on print driver ie Control panel/printer and fax's right lick on epson driver, properties.
Still needs a colour cart installed.
Posted on Nov 16, 2007
0 characters
3 Points
Don't print in color
It's your printer head problem. Your printer head is now block. To remove the problem try to follow the proces:
1. Take some amonia solution ( amonia30%+ water70%) in a plastic seringe.
2.remove cartriges from cartrige holder.
3. Then set the seringe nipple in one stick (that is into cartrige holle all time while cartrige is push).
4. Then push the solution in to the black plastic stick.
Use these proces 5/6 time one after another to a black stick.
I think you may relive from your problem.
Thank you
Jun 16, 2011 | Epson Stylus C82 InkJet Printer
New ink but want print letters printer type epson c82
Hi there follow the steps below.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope thats start working , if no luck then un install the printer driver & restart the PC & Printer both again. NOw install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
May 24, 2010 | Epson Stylus C82 InkJet Printer
I have windows 7 and my printer won't print. it moves like its printing but it doesnt
You may need to download an updated driver from the Epson site. Another ugly thought; if your printer has been off for a while, it may not print at all anymore. The brand is great for hard use, lousy for only occasional use. The ceramic printhead will clog and print no more.
Oct 30, 2009 | Epson Stylus C82 InkJet Printer
Trouble with my epson stylus c45 printer. PLEASE HELP!?
this is usually caused by clogged print heads, unfortunately epson is still one of few brands that still manufactures most of their printers with the heads built into the machine and thus upon print head clogging the printer must be taken in to be serviced or buy a new printer that does not have the print heads built in but rather built into the ink cartridges. hope this helps.
Sep 30, 2009 | Printers & Copiers
Epson Stylus C82 InkJet Printer not printing
In view of the original poster's lack of interest in this problem, I think we can post it as "Solved by Poster"
Nov 16, 2008 | Epson Stylus C82 InkJet Printer
Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Apr 10, 2008 | Epson Stylus C84 InkJet Printer
Printing problem
>go to printers & faxes
>right-click on the printer icon and select Properties
>click on the Print Test Page button
>windows test page will print - if issue still persists : uninstall driver from the XP Control Panel -> Add & Remove Programs -> EPSON Printer Software
>reboot computer
>re install printer driver
Dec 31, 2007 | Epson Stylus C82 InkJet Printer
New black ink, but wont print any black ink
Epson Printers are terribly designed. There is a known issue with them related to clogged ink wells. Below the cartridge the ink dries in the well and makes the printer unusable. I have seen this many many times and will NEVER recommend an epson printer. Most of the time I will have people go out and buy a new printer only because of the fact that you will be paying 50-70/hr labor for someone to FIX/Clean your printer. If you want to try to clean it yourself go ahead. I have done it in the past with varying success because it is more trouble than its worth to remove the inkwells and clean them properly. Buy an HP printer. The difference is that the HP cartridge is what contacts the paper directly. There is no inkwell inbetween to get clogged. When you buy a new HP cartridge you will replace everything between the ink and the paper. Epson is just a poorly designed product. Hack
Jul 09, 2007 | Epson Stylus C82 InkJet Printer
Trying to print black only document
the problem with this printer is that all the inks have to be at a usable ink level, if any one of them are below the acceptable amount it will not print in any colour at all not even black.
Jun 25, 2007 | Epson Stylus C82 InkJet Printer
Epson Stylus C82 InkJet Printer Logo
49 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
