Question about Toshiba Satellite A135-S4527 Notebook
Compute wont run off battery - Toshiba Satellite A135-S4527 Notebook
  • 585 Answers
Most batteries have a "Battery Check" button right on the battery with a bar-graph indicator to tell if the battery is any good. If the battery check doesn't show good, replace the battery. If the laptop is left plugged in all the time, the battery may well be "cooked" I've seen 6-month old batteries cooked to death this way. And I mean there was just nothing left, like the battery wasn't even there.
Posted on Jul 14, 2009
Worked off the battery but it wont charge or run off power cord adaptor
Check and make sure the power adapter doesn't have a fuse somewhere in it. Then chk the wattage output of the adapter. Watts should be marked on the adapter.. Now see what the computer requires. Computer info is on the sticker on underside of computer.To determine how many watts the computer needs, Note the amps the computer draws(on label) and multiply the volts(on computer again) x the amps. Answer will be your needed wattage.
Use only the adapter that came with the computer. They may look alike, but there is a difference. Make sure the computer is powered off. A full charge is needed now since the battery was dead. Allow time and don't use the machine prematurely.
Make sure the adapter output matches or betters the requirements of the computer.- Good Luck-Ned
Jul 23, 2014 | Barco R9852000 LC40 Compact PC (R98 52000,...
Have new battery will not hold charge and car wont run with car running disconnect
Never disconnect the battery when car is running. I know that used to be the old way to check if alternator was working, but that was before electronics became the norm on vehicles. On today's vehicles, or any with a computer in it, disconnecting the battery with key on, or engine running, there is too great a chance you could fry the delicate electronic circuits that the computer requires. Always turn key off before disconnecting the battery.
Okay, enough soap-boxing. You need a new alternator, if the car won't run with battery disconnected. Next time, use a volt meter.
Jun 14, 2012 | Ford Thunderbird Cars & Trucks
Runs on battery only wont charge or run on ac power charger working on another laptop fine
Computer power probems are traceable to batteries, ac cables and power outlets. First, the computer batterie should charger fi were situated appropiated in the compartments without ac cables power cord malfuctions.
Jan 28, 2011 | HP Pavilion dv6000z Notebook
Hi! my dell d800 wont turn on. I have take then battery out and such and then put it back in but it still wont work. I have put the charger into the computer and the computer says its not charging the...
the battery is damaged..replace the battery with a new one or you will have to run your laptop straight from a eletric power source with the battery removed.
May 02, 2010 | Dell Latitude D800 Notebook
I HAVE A 1995 CADILLAC ELDORADO AND NEW BATTERY WONT CHARGE
altenators have to be running a 13.5 volt charge to be good
Mar 12, 2010 | Cadillac Eldorado Cars & Trucks
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
My computer wont start up
remove the battery and wait about 20 min and pulg it up with out the battery
Dec 12, 2008 | Dell Inspiron 5150 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Battery or No
Yes it will (or should ) work without a battery, just make sure you don't unplug the connector while you are working with your computer or you will loose your work w/ no warning, laptop power cords become detached easily so be careful!
May 13, 2008 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
