Question about Naxa Electronics Naxa Detachable PLL Electronic Tuning Stereo AM/FM.MPX Radio MP3/CD Player-ID3 Text Function
How do I erase everything on the unit? - Naxa Electronics Naxa Detachable PLL Electronic Tuning Stereo AM/FM.MPX Radio MP3/CD Player-ID3 Text Function
How do i erase everything and start from fresh?
Posted on Jul 15, 2009
How to reinstall windows and all drivers
1. Go to applications screen and touch the settings button.
2. Touch the Backup & Reset option.
3. Select Factory data reset.
4. Leave the erase SD card option unticked and touch Reset tablet.
5. Touch erase everything.
6. The unit will now reset itself back to factory reset and any previous information/data will have
been permanently erased.
For further help and support with your device including how to
install software updates if available and much more:
http://www.hannspree.com/
Dec 29, 2013 | Hannspree HannsBook SN10E2 Atom N470...
Record is full. how to clear.
I'm not sure if a global erase is possible, but since you want to erase everything you don't have to worry about making a mistake, right?
I didn't see such feature in any of these little units, so I suspect you'll have to ERASE one file at a time. Your User Manual has the instructions I'm sure.
The operation of erasing is not exactly the same with all makes and models.
In some, you need to press ERASE as the file is playing back, while in others, you just go to the file number and erase it.
In this case I imagine you can go to the first file in each folder and erase away.
Jun 02, 2011 | Samsung SVR-S820 Digital Voice Recorder
I format my memorex mmp9490 now everything is gone
Im so sorry for you. But I must say that once you Reformat any electronic object, your unit will be erased complete, period. For the future remember to backup everything on your disk before reformatting.
Feb 26, 2011 | Memorex MMP9490 Digital Media Player
Nuvi 760. Was working, then it just went off. Cannot get to come back on. Is there a reset somewhere?
If you want to reset your unit, here are a couple of steps you can do:
1. If the unit is hung, slide the power switch and hold for 5 or more seconds until the unit resets. Note: when you slide the power switch to on and continua to hold it, you will briefly see the Garmin screen and then it will disappear on you while you are holding it for more than 5 seconds. This is a normal behavior and it is ok. Now just simply slide the power switch back on.
2. If you want to reset everything that you have had on your unit back to factory settings, meaning all user data, press and hold the lower right corner of the screen and then power the unit on, a dialog will come up asking if you want to "Do you really want to erase all user data", select yes. This option only erases data in the unit's memory that isn't accessible to the user (ie. what isn't accessible when you connect the unit to your computer). It doesn't erase any .gpi or .gpx files you loaded (if your .gpx files contain any waypoints then they will automatically be imported into your Favorites), it won't erase any mp3's, jpg's or any other files that you have loaded.
3. At the main menu of Garmin Nuvi, press Tools, Settings, System, and Restore. A dialog will come up asking if you want to "Are you sure you want to restore the default settings?", select yes.
I hope this help
Joe
Nov 28, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Fully charged put on cradle fatal alert/fatal exception/reset
the lightning bolt is normal ..its telling you the battery is being charged .. if you get an error code or if the unit quits working then you can do a reset or a "hard reset" ... the hard reset erases everything and will restore the unit to factory conditions .. to do a reset .. unscrew the top of the stylus .. that gives you a probe to push the reset button on the back (top) .. if you hold the power button in while you do a reset then it gives you a choice to "erase everything" .. if you accept then thats a hard reset ... if everything else fails .. do a hard reset .. you can do all this while its on the charger so if you have a bad battery that wont matter .. if the battery wont hold a charge then it can be replaced ..
Sep 03, 2009 | Palm m515 Handheld
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset...
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Dec 20, 2008 | Garmin iQue 3600 GPS Receiver
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Feb 23, 2008 | RCA RP5030 Digital Voice Recorder
Unit not recognised by my computer or any other, and memory issues on another unit.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260, with Rhapsody. Sansa turns on, off, on, off continuously
Uninstall the MTP device in your hardware device manager, or remove it using add/remove hardware in control panel
Then:
or
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e260 MP3 Player
Erasing some or all stored numbers from memory
Im sorry I dont know buit you must have an instruction manual that can assist you and if not maybe a tech assist # in the papers you got with this unit as everything I look up fopr this unit says discontinued!! sorry man I've tryed now for two Days and a friend tryed his sources too to no avail.. Sorry >:{
Apr 10, 2006 | TT Systems 3460 2.4GHz Phone (IBM-3460)
Car Audio & Video Logo
168 people viewed this question
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
