Question about Beckett Corporation Beckett Professional Pond Pump, 3500 gph
Pondmaster Mag Pump 1200 gpm has electrical short. When the cord at the pump is moved the pump goes off and on. Can I repair this? (i.e. can I get into the water tight case?)
  • 990 Answers
You can get into the case ok but this is probally in the cord and getting that free from the caseing is the trick and then getting it back together so it won't leak is yet another. after some thirty years in the buisness I've found that due to exposure to the elements the cord you pull into the seal and the cord seal it self will not hold water for more than a few months and new parts wait time and aggrevation make replacement an option. But if it sounds like I'm saying don't try this, I'm not. What I am saying is if you try to fix it and it dosen't work don't feel bad, your not out anything but your time. If it works you win. When you take apart the back of pump you will find a rubber seal as you will find a comperssion seal around the cord. First usins a fine wet and dry sandpaper roughen the cord outside the pump and the rubber seal at the rear plate do not lube these. Pull some new cord through tighten compression seal at cord trim cord and rewire pump past weak spot caused by pump housing reset back plate tightening evenly and firmly but not so tight as to cause plate to warp. then tie off cord to some place on pump so if some one pulls on pump it isn't pulling on cord at houseing.
Posted on Aug 24, 2009
Why is it not pumping?
Pondmaster pump repair part 1 - YouTube
? 3:12
www.youtube.com/watch?v=KFbe0xmk2tk
Oct 29, 2011 - Uploaded by Asianleful Pondmaster pump repair part 1 ... How to build a simple PVC Hand Pump - the Peters Pump - Duration: 20 ...
Aug 07, 2015 | Pondmaster Garden
I just bought the Pondmaster 260 pump from Overstock. There are NO instructions in the kit. Do you have a manual I could download on line? Thank you. Ellen Goodell
The manual is located on the Pondmaster site in PDF format: http://www.pondmaster.com/instructionsheets/ZG098.PDF
If you need the program to view it the reader is free at: http://www.adobe.com/products/acrobat.html
May 12, 2011 | Pondmaster PM 250 gph Mag Pump Pump 250...
Wher does the o ring go on my pump? I cleaned it & didnt even realize it had an o ring til now
The O ring goes between the impeller housing cover and the pump. Remove the 4 screws and pull the housing cover off and you will see a thin groove that the O ring fits into.
Nov 14, 2010 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
Mag 7 pump does not work
prime pump till over flows connect lines make sure no leaks pump has low or no water shutoff built in make sure intake is completly submerged at all times, hit reset switch
May 09, 2010 | Pondmaster Pond - Mag 7 Pump, 700 Gph
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Oct 31, 2008 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Beckett Corporation Beckett Professional Pond Pump, 3500 gph Logo
298 people viewed this question
Top Beckett Corporation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Beckett Corporation Garden Expert? Answer questions, earn points and help others
