Question about Samsung SGH-E370 Cellular Phone
Charging problem phone won't charge pluged intl several outlets and won't charge
  • _callum1991_ Jan 08, 2008
    if i plug the charger in it says that its charing but it drains the battery and the battery is fine
    New Friend:
My Palm Pixi went dead last night. I've never dropped it. It's never had any water damage; it's been taking care of extremely well. I went to charge my phone and my phone won't charge. I took the battery out and put it back in, tried to charge my phone again, and it still won't charge. What should I do?
Posted on Jun 30, 2013
  • 316 Answers
Check the base connection this can be damaged if the charger is inserted the wrong way.
If this has happened then you will need a tech to repair it.
If it is not this then I think your battery has died
Posted on Nov 16, 2007
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIT for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
Dec 08, 2017 | HTC Droid Incredible 2
Why isn't my phone charging its pluged in and it
You can try to try a different charger,if it doest charge the battery,try to use your charger to a compatible phone. If it charge the second phone,that means that your charger is fine,it might be a battery issue. For sure,either the battery or the charger needs replacing.
Dec 07, 2011 | LG Cell Phones
Phone wont charge so will not turn on
Have you tried more than one power outlet? It could be the power outlet you're trying to use isn't functioning. If it won't charge on a different outlet, the issue is either the charger you're using or the phone itself. Try wiggling the charger around while plugged in to the phone, see if that will charge it at all. You should also trying getting a different charger and see if that will work. If not, you may just need to replace the battery/phone.
Aug 14, 2011 | Ericsson Cell Phones
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
Ambiedabambie@aol.commy phone won't charge
Charger connector to phone worn out, wiggle it around to see if it starts charging.
Not plugged into a live outlet.
Charger broken, replace.
Phone battery failed, replace.
Call or visit your carrier and ask for help.
Jun 16, 2011 | Cell Phones
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
the issue here might be that the battery of the bluetooth device might have gone bad and just need repacement ofcourse that is not until after you have ensured that the device was week pluged in to charge..
try charging al over again ensuring its well plugged in and the power in the outlet you are using..
then try replacing the battery...
Feb 03, 2011 | Motorola Cell Phones
the battery must be completely dry of charge. first charge the battery alone for 30sec using a 6volt dc eleminator and then put the battery in the mobile and charge for 15min an the switch on the mobile
Jul 24, 2009 | Cell Phones
Samsung SGH-E370 Cellular Phone Logo
88 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
