Question about Refrigerators
Water is pooling on the bottom shelf and in the
Water is pooling on the bottom shelf and especially in the crisper drawer. If it gets overfull, it comes out the bottom. Don't know where it's coming from. Help, my veggies are drowning!
  • 10,865 Answers
Hi I can help you with this annoying problem.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Jul 14, 2009
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
Water is pooling on the top shelf and under the crisper drawers
ur drain is clogged. remove freezer panel and unclog hole where water collects
Feb 12, 2010 | Kenmore Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water is pooling in the bottom of my roper refridgerator.
check door gasket all the way around , check water line inside frige behind crisper drawers
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
355 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
