HELP Installshield is giving me problems
When trying to re install my Sims 2 I can only install to 23% then the program quits responding. My e-mail is lori_craig_n@yahoo.com
I ended up having to completely deleting and overwriting my computer. I then had to reinstall all programs.
Posted on Nov 24, 2007
    Novelist:
  • 150 Answers
Did you uninstall SIMS first? I would ask if you have added any new devices (like a new video card) to your machine. The idea is that a device driver is being installed and there may be a conflict or file that is locked while installing. Do you actually get an error? Please indicate it here.
1) Uninstall SIMS
2) Shutdown the computer, wait for 15 seconds
3) Restart the machine, if any new changes occur, let them happen, then start at 2 again until nothing updates.
4) Reinstall SIMS
If these don't work, make sure your machine still meets the minimum requirements of the game.
Also, see that the disk is clean. Possibly make a backup copy of the game on DVD/CD and try from that.
One more thing, make sure you scan your system for Virus.
Posted on Nov 23, 2007
When I try to save and quit, Sims 3 Showtime, I receive an error message. The game won't save my progress. Then I get a message from windows saying the Sims 3 is not responding and it shuts the game
Ok, not really sure if this will help.
Right mouse click the Sims 3 icon and choose properties at the bottom. Then choose the Compatibility tab and at the bottom, check the button: Run this program as Administrator.
Hope this is helpful.
Nov 13, 2014 | Electronic Arts The Sims 3: Showtime...
Installation codes sims 3
The 16 digit code is for expansions, this article will show you how to redeem it: Sims 3 16 digit code needs to be 20 digits
Aug 01, 2014 | Electronic Arts The Sims 3: Into the...
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
Run-time error '-2147467259 (80004005)': Unrecognized database format 'C:Windowssystem32wints.dat'.
To fix this program, you need to rename a folder containing a previous version of the installer. Open My Computer and navigate to C:Program FilesCommon Files. Right-click the Installshield folder and select Rename. You can rename the folder anything, but, as Google suggests, something like Installshield-old will give you a hint about the folder’s previous name. Close My Computer and try running the installer again. If that doesn't work tell me and I will see what I can do.
Aug 19, 2009 | Microsoft Windows Vista Home Basic Edition...
Microsoft Runtime error 6002
To fix this program, you need to rename a folder containing a previous version of the installer. Open My Computer and navigate to C:\Program Files\Common Files. Right-click the Installshield folder and select Rename. You can rename the folder anything, but, as Google suggests, something like Installshield-old will give you a hint about the folder’s previous name. Close My Computer and try running the installer again. If that doesn't work tell me and I will see what I can do.
Thank You,
Ryan Frame
Creative Energy Associates Technical Center
Jul 28, 2009 | Computers & Internet
Help me
you cannot download sims games because you need the sims disks to play the game nad when you install the game and expansions the install wizard will tell you wich disk you need to play the game.
Aug 16, 2008 | EA - Electronic Arts Sims: Complete...
Desktop Software Will Not Load!
The problem that you are encountering right now is a windows problem. "idriver.exe" is related to the installshield application on your computer and installshield is used to install application on your computer, so if idriver is not working, installshield will not work also. I suggest try the windows update. It might fix the problem.
Sep 11, 2005 | Palm Tungsten E Handheld
Error Containing "0x123454" when installing software
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Computers & Internet Logo
321 people viewed this question
David Payne
David Payne
