Question about Asko Washing Machines
ASKO 10505 front loader washer spare parts
I need a new control panel cover. ie is the part that sits over the knobs and control buttons. Can anyone tell me where I can get this part from?
    President:
  • 2,187 Answers
Are you referring to the front panel? Please see link below if it has the part you need. Thanks
Part: 8063046-0
Washer Parts
Posted on Jul 14, 2009
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko 10505 will not spin the belt is not broken, tub fills and drains
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Jan 29, 2010 | Asko Washing Machines
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
