Question about One For All URC-3021 Remote Control
My tv/video button
I cant get the remote to work all the way the only thing that works on it is the volume,channels and thats it wen i say chanels i mean it lets me change the channel
  • 259 Answers
Re: my tv/video button
Not sure if this remote supports TV/VCR button. You might have to try anothers companys universal remote. Like sony universal remote for sony TVs Phillips universal for Phillips TVs ETC... Hope this helps. : } SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
Posted on Dec 12, 2007
0 characters
3 Points
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Remote Controls
I just bought this 25in zinith tv!!it has a remote but i cant figure out how to get v1 and v2 chanells so i can watch netflix on it? can anyone help me?
19 worked for my Samsung Blu-Ray player remote
Now I can ctrl mute, volume, channel up-down and power on/off on VIZIO (M470NV) 47" Razor HDTV, thanks
Sep 04, 2013 | Zenith ZEN700 Remote Control
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
Iv lost the remot for my nec cromavision flat tv and the child lock is stuck on
Just check an other code from the remote catelogue for NEC. Some codes might not work all the functions to TV.
Mar 30, 2012 | Remote Controls
When I click chanel up or down the tv says please
For the Dynex ZRC-102 remote control channel switching.
1. Press the MENU button and select SETUP.
2. Go down the list and select FAVORITE CHANNEL MODE and switch it to OFF.
The +/- CHANNEL buttons will then switch channels when pressed.
Sep 28, 2009 | Remote Controls
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Feb 21, 2009 | Remote Controls
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
One For All URC-3021 Remote Control Logo
83 people viewed this question
Top One For All Remote Controls Experts
Are you an One For All Remote Control Expert? Answer questions, earn points and help others
