How do i fix TCP_ERROR - Computers & Internet
  • sodhi_1981 Jul 14, 2009
    window vista, cacheflow ca-645 proxy server
Please provide the operating system you are using and the make and model of any devices this relates to.
Thanks.
Posted on Jul 14, 2009
TCP Err 10050042
I have no idea about cash registers but a TCP error sounds me to Internet connection. Chack if this might be the reason
Jun 26, 2015 | Retail Supplies
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
Tip
How to Troubleshooting Network
Here you will learn network troubleshooting tips, fix tcp/ip errors, tcp/ip settings, internet connectivity errors, how to fix pc errors, lan connectivity issues, traceroute and ping commands. Whether your operating system is Windows or Linux network problems are likely to arise. Many times the network problems arisee due to improperly configured TCP/IP settings. Following is the basic checklist to identify and troubleshoot the basic networking errors.
1. First of all you should learn what stopped working server or client computer also see if the outage affecting the other computers or only one.
2. If you server stopped working you should inform the users of the server and you should start working on fixing the error.
3. If a single client computer stopped working or disconnected from the network, ask the user of that computer that what recent changes cause the server to stop working such as newly installed software or games, service packs, internet software, new hardware or any other thing.
4. Check the physical network connectivity. The most network problems arise due to the physical layers failure.
5. Check all the network cable connections. You can start at the NIC and check if the green light is blinking then check the hub and see if the computer is getting the link across the cable.
6. Get a cable tester to check the connectivity of the cables.
7. Finally start pinging the network both Windows and Linux have the PING command. You can use ping command in this way start > Run > cmd > type "ping" then IP address of the other computer
on Mar 25, 2010 | Computers & Internet
How to fix Error Code E000732-001
Check the connection from Fiery to reader controller PCB, located on the left side of the machine, just beside the TCP /IP port connection.
Jul 07, 2014 | Canon imageRUNNER 8500 Copier
I am having problem with my cable net my laptop giving error 720 and when i troubleshoot it says DNS error in connecting net
Check TCP/IP filtering properties: Open TCP/IP properties of the
connection, Advanced button, Options tab, TCP/IP filtering properties.
If filtering is enabled, change all to permit all instead of permit
only. save the changes and then return to disable filtering.
Nov 20, 2013 | Computers & Internet
Error code tcp on internet connection for sharp tv
Yes, my firewall was blocking it. I got around it and it fixed the problem.
for more help visit CBR Tech Solutions
Apr 21, 2012 | Sharp LC-70LE640
Error 80028e02 cant play online
PS3 error 80028E02 can be caused by different source of network showcase270.jpgblockages. If you happened to be in a filtered network, that's your most probable reason why your PS3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your PS3 to connect online.
If the modem or router is blocking your connection then it can be fixed by opening some ports
you will have to call your computer vendor to open the ports
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Nov 24, 2010 | Activision Call of Duty Black Ops
I want to play cod 4 on line and when i go to sign in it comes up dns error how can i fix this
You will need to do port forward :
Call Of Duty 4 28960 28960 TCP/UDP
Call Of Duty 4 20800 20800 TCP/UDP
Call Of Duty 4 20810 20810 TCP/UDP
Nov 13, 2009 | NetGear DG834G Router
Tcp error on connection in internet
tcp error means there is something wrong with TCP/IP PROTOCOL, with is basic network service. try restarting services. if it won't work there may be something wrong with DNS server
Oct 05, 2009 | Microsoft Computers & Internet
Computer
You are going to go to the tcp/ip settings and enter a permanent ip address.
If you access the internet you could always use the ip address you are getting from dhcp, just go to start-run and type cmd then at the command prompt type ipconfig and copy the ip, subnet, gw and dns to the tcp/ip settings.
Thank you for choosing agadycom.
Nov 13, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
