How do I replace the monitor cable on a gateway gz7330?
  • kcbee58 Jul 14, 2009
    I rather needed instructions on how to do it.
    Sergeant:
  • 259 Answers
Parches the new cable and after install new
Posted on Jul 14, 2009
I am trying to connect to gate way monitor
You need a cable from the "audio-out" from your laptop to the "audio-in" port on the Gateway, to transmit the sound to the monitor.
Apr 21, 2015 | Dell Computers & Internet
Gateway fpd1530
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
Fuzzy screen on Gateway FPD1975W TFT LCD Monitor
With the pixels acting up and the monitor having the same problem on any computer that its connected to. The screen itself is bad and since there are no replacement screens for that monitor, you would have to buy a new monitor or get it replaced if its under warranty.
Jun 02, 2010 | Gateway FPD1975W 19" LCD Monitor
What cable for Gateway FPD monitor to Dell Dimension 2400 compute
You can either use a dvi or vga cable, for more info go to http://service.gateway.com/s/Manuals/Monitors/8511253.pdf
Mar 03, 2010 | Computers & Internet
Screen just showing white.
Have you already tried replacing the cable? If not, check the cable connections to make sure it's plugged in properly. If this doesn't help, duck out and borrow a replacement cable and see if it works better.
Does another monitor work OK on your computer? It's also possible that the graphics card could be your problem. Check the cable and another monitor if need be - let me know if you need further help
Good luck,
Sherwin
Dec 20, 2009 | Gateway HD2200 LCD Monitor
GATEWAY 2275 LCD MONITOR WENT OUT, WHEN PLUGGED
This could be due to a bad power supply inside the monitor witch is replaceable for like $25 bucks all you got to do is unscrew off the back undo a few cables and put in the new supply.
I hope this helps you in the repaire process if its under warrenty please seek warrenty guidlines.
Jul 17, 2009 | Gateway FPD2275W LCD Monitor
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
