Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Sony Beta sp deck 1800 wont take larger tape down
Shows error message 21-1C1. Will take the smaller tapes fine. Is the a setting or a reset for this tape size?
    Champion:
  • 221 Answers
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Posted on Jul 16, 2009
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Receiving and Error Code 5
Error 05 points to a problem with one or both reel motors. Not field-repairable for a non-technician.
Mar 25, 2009 | Sony PVW-2800 VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
DSR-11 stopped outputting anything
I have almost the same problem!  Did you ever figure out what happened?  Here's what I had posted yesterday:
Tech Friends -
I recently got a non-sony tape stuck in my DSR-11 (bummer) and was forced to extricate it using the "my tape got stuck in the DSR - 11" article's method of removing the top cover and highest level of circuit board:
http://www.fixya.com/support/t178954-tape_stuck_inside
This worked for the tape removal, however, upon replacing the circuit board and cover, the deck no longer seems to be able to do anything with video or audio.  It still communicates with FCP via its firewire connection (ie FCP is able to control FF, rewind, play functions, etc), but it seems unable to read or write video.  Also, we use it as an A - D converter box between a Beta SP deck and thecomputer (actually, this is the deck's main function here).  Even when I switch it to the correct setting (video) and check to make sure that everything is plugged in correctly (trust me, I checked, it is), I get the "there is no video here" error message.
Also, after trouble shooting the drive for a little while, I pressed the "reset" button the the rear.  I'm not sure if that matters one way or the other.  I don't think it does (that just resets the time code, right?)
The question is, would this be a case of "fried firewire jack" such as it seems so many of us DSR - 11 owners have?  Could I have done any frying myself by not having myself properly grounded when opening the shell?  Is there anyone who knows the answer?  Help!  I can't digitize my video!
Comment by eltriunfo, posted on Sep 05, 2008 The Plot Thickens...
Okay, I've checked all of the FCP settings and played with the deck more and it's only confused me more.  I can now get it to not only be controlled by the computer, but actually print audio and video to mini dv tape.  Also, I can record from my Beta SP deck to miniDV tape in the deck (connected through the "video" input on the rear of the unit).  In other words, the deck seems to function perfectly doing everything except for converting analogue to digital passively.  The way we always did it before was by keeping the input switch on the face of the unit on "video" and log and capturing in FCP with it as a noncontrolable ntsc device.  This makes me understand it less.  It means to me that it is not a broken switch, it's not a broken firewire port, everything works perfectly EXCEPT for using the unit as an A-D converter.  What the dill-yo?  If anyone in the world could offer any insight as to what could be causing this I would greatly appreciate it!
Jun 19, 2008 | Sony DSR-11 DV / Mini DV VCR
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
882 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
