Question about Karcher 1750 psi Electric Pressure Washer
Problem with pressure washer line seems to be cracked the line that has the gun and puts the water out has a crack how do I get a new one?
    President:
  • 1,273 Answers
Lowe's and Home Depot keep a supply of hoses. Take the old one with you, and match it up. Or, you can take your make and model number and order one on-line.
Regards, --W/D--
Posted on Jul 14, 2009
On my 2002 sr5 sequoia radiator doesn't seem to be building up pressure,but,everything seems to be working properly ??? any comments??
leak in the coolant system
possible causes
cracked plastic radiator tanks ,
cracked hoses
rusted welsh plugs
corroded housing behind water pump putting water into sump ( grey sump oil)
have it pressure tested to find the fault
Jan 08, 2017 | 2002 Toyota Sequoia
The trigger on my Ryobi pressure washer won't turn off and ter leaks out from it. Anyone know what the problem could be?
I had this problem as well. The valve inside the gun cracks causing it to leak. I repaired mine with fast setting epoxy and a hose clamp. Disassemble the gun taking note how the parts are assembled taking pictures helps. Look for the crack sometimes it is not very visible check the ends where parts come together. Mine was where the tube that the trigger connects to enters the tube where the hose connects to. Epoxy the OUTSIDE of the crack not inside the tube because it needs to be smooth in order for it to seal properly. Try to get some epoxy inside the crack then use the hse clamp to hold it together while the epoxy cures.reassemble the gun and test. Sometimes the O-Rings will need to be replaced oil the orings while assembling the gun to prevent damage to the orings.
Oct 25, 2016 | Garden
Oil is milky colored on my kingcraft pressure
Milky-looking oil is a sign of water mixed-in with the oil. This is often a sign of severe engine damage (cracked block, cracked head) in a water-cooled engine. (i.e., one having internal water jackets such as a car engine). On a pressure washer it is sometimes an indication that the owner used the pressure washer on itself, i.e., so as to clean the pressure washer with the pressure washer - very bad idea. If this is the case, then the pressure washer is most likely ruined. In any case the milky-looking oil is a sign that the oil has become contaminated with water, and probably a lot of water. I would drain the oil completely and replace the oil filter too if it has one, then refill the crankcase with new oil. Then try using it again for 10 or 15 minutes or so, then reinspect the oil. If it's milky-looking again then I'd set it out at the curb on trash day.
Oct 20, 2014 | Garden
Water leaking out of bottom of washer
It sounds like water was left in the pump and i froze over the winter and cracked the pump housing. You can try taking the gun hose off and blow compressed air where the hose hooks on to blow waterwater out of the pump and dry the bottom. Then put some apoxy on the crack to seal it.
Mar 18, 2011 | Karcher 2500 PSI Pressure Washer
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Ive noticed hairline cracks in the neck of my
In any pressurized system a crack will reduce your pressure. I'm not 100% familiar with this gun so I cannot be sure of exactly where the cracks are. Any time you have a screw on lid, or some type of cam that tightens the lid it's pressurized. Though this may last for years like this, I would not spray with it if it's cracked. It could be dangerous and very messy if it breaks.
Nov 28, 2009 | Air Tools & Compressors
Karcher K 3.86 electric. Was working fine and
It sounds like you have cracked part inside. Parts availability depends on were you live???
Sep 18, 2009 | Karcher K 2.25 R Electric Pressure Washer
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
102 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
