Question about Troy Bilt Tb70ss Gas Trimmer
New spool only lasts a couple of minutes and is gone
Once i re spool it just feeds out until its gone.
  • 134 Answers
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring, or some other missing part.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. With the best intentions, lubrication inside this mechanism will cause continuous string feed. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Posted on Jul 19, 2009
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 | Garden
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 01, 2011 | Homelite Garden
I have a brand new Lincoln pro mig 140. Took it out of the box and set it up yesterday. After approximately two hours of mild steel welding today the wire drive roller quit working. I've tested the...
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
Oct 18, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
How do you remove the line feed to replace with new. Is is scred on or does it have a lock washer
It should be screwed on. There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 17, 2009 | Craftsman Convertible 25cc. Gas Line...
Cub catet weed wacker needs new string and I don't know how to put the string on....
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 30, 2009 | Garden
Load new line onto the mighty vt26 17" curved trimmer
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
Jim
Don't know how to install new string on Echo SRM 2400
Jim
Jun 29, 2009 | Echo Rapid Loader, Trimmer Head
I have a robi 31cc don't know how to put on new string has double head i can't put the string on
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Jun 15, 2009 | Ryobi Garden
Ryobi 725R weedeater
First unscrew the bump line leter outer. Then remove the yellow line holder, you will see 2 line grooves for each of 2 lines you will wind into the spool. You will see an inlet area at each of the 2 line holders, you will take about 8-10 feet of line and thread the line into the the groove inlet it will poke out the top of the spool. You will see 2 small holes on the top of the spool, feed just the tip of the line into the hole and pull the line tight on the groove side. Do this on both grooves on the spool, once the line is secure, fish each line into the holes on the spool head and secure with the bump spool leter outer. After spool is secure take the entire spool and wind back into the spool head. you will see the line wind into the spool. make sure you wind the right direction. Once you have seen how this is done, look at the bottom of your assembled spool and you will see 2 arrows. If you have no line in the spool, line up the arrows and take 8-10 feet of line and feed as you did when you have the spool removed. The line should feed through the spool and the line will stick up from the bottom, turn the line and feed just the tip of the line into the retainer hole and pull tight from the spool let-out, once secure wind line back into the spool. Once you have done this once its very easy to do over and over!!!
Jul 21, 2008 | Electrical Supplies
Troy Bilt Tb70ss Gas Trimmer Logo
283 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
