Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Horizontal won't stop fluttering
Set use to take long tome to come on. Then it would take long time to come on and at first the horizontal would keep fluttering. Now takes long time to come on and horizontal won't quit fluttering
  • oscar1954 Nov 29, 2007
    this would take care of horizontal but would still take long time(up to an hour) to come on with sound and picture. What about this problem?
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Call tech and suggest to repair the horizontal drive ..
Posted on Nov 26, 2007
Chain saw won't keep running
There are 2 adjusting screws, one is idle speed and the other is mixture. Adjust the idle screw until it keeps running. That may be all you need. But to check that the mixture is right turn the mixture screw, quarter turn at a time, keep count! until it flutters or speeds up. If it speeds up stop and adjust the idle back a quarter turn at a time until it runs without the blade turning.
Oct 25, 2016 | Garden
It runs good thin it bogs bown and flutters
what fuel mix are ya running you should be running 40.1 or 50.1 somethings causing the engine to get to hot to run it should run cool to keep running
Nov 02, 2009 | Poulan Featherlite Gas Blower, with Low...
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Oct 20, 2009 | Seiko Watches
Fluttering noise in engine while accelerating at a fast rate
I believe you may be referring to 'pinging', Try a tank of premium gas and see if it stops. Check your timing, and when was it last tuned? Let me know what u find. countrycurt0
Oct 02, 2008 | 2002 Ford Explorer
Fluttering glitchy screen
if your laptop supports dual monitors then it's a pretty easy fix. Plug in an external monitor and secure the screws. reboot your system and it will recognize the external monitor and set it up as your main monitor. you now have access to all your files w/o the cost of replacing your laptop screen (which would cost about as much as a new one). ^_^
Aug 01, 2008 | Toshiba Satellite A55-S1063 Notebook
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Stalling and fluttering
Have you checked your vacuum lines? Also the fuel filter or the gas line might need replacement.
May 18, 2008 | 1994 Chevrolet G20
Continuous rolling screen.
check out and find the error code
Dec 24, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
127 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
