Question about Dometic Rooftop RV Air Conditioner
Red light flashing inside the unit. Is this a
Red light flashing inside the unit. Is this a problem. The unit appears to be operating fine
    Champion:
  • 233 Answers
Generally speaking it is not, if it is a slow steady flash, this is referred to as the "heartbeat" by techs, if the unit is operating correctly that would be my assumption that it is just a "status" light
Posted on Jul 14, 2009
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Red doesn't seem to be working properly, but doesn't appear to be a bad projector.
The red CRT tube is failing. They are rated at 3000 hrs of operation. Check the red CRT face to see if there is a lot of dirt on it or has a discoloration on the inside of the coolant chamber. These tubes are scarce and expensive. You may want to consider a new TV.
Apr 27, 2017 | Hitachi 46W500 46 in. TV/DVD Combo
I need a list of codes for my lennox hp26-036-7p the red and green lights on the outside unit are flashing continuously. the outside unit acts like it wants to come on and i can her it running but it is...
LED Flash list should be located on the inside of the unit's electrical panel by the wiring schematic, and by counting the flashes in between the longer pauses should give you the diagnostic code. A continuous steady flash can also mean normal operation, and something else on the inside could be holding you out like a float switch tripped (located on emergency pan underneath Air Handler Unit If Applicable) etc.
Jul 05, 2011 | Heating & Cooling
Receiver will not operate. when powered on red light flashes, menu displays, than thee is a loud click and the red light keeps flashing. tried the reset and it still does not work.
This sounds like the unit is going in to protect mode. See the link below for further information. Specifically to your unit, we need to know the model number. Also, try disconnecting the speaker cables completely and try again. Update this with how the unit reacts. If the unit powers up fine, then there is a problem with either the wiring to the speakers or the speakers themselves.
Please keep us posted.
Thanks,
Dan
Jun 17, 2011 | Denon Audio Players & Recorders
What is the problem when red light is appear?
the other tech is correct but theres also other causes. if 4 red lights are flashing making a full ring your av plug at the back of the xbox is not plugged in. if it has 2 red flashing lights yor unit is overheating. 3 red flashing lights means your cpu is unstuck and is stuffed. 1 red flashing light is a HDD issue
Jun 16, 2009 | Microsoft Xbox 360 Console
Flashing red light on ice maker control unit inside freezer
I understand the price seems pretty high have you tried an OEM for a better price. I am understanding that your filter is a common filter 4396510 I think is the aftermarket number
Apr 15, 2009 | Refrigerators
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
I have Fujitsu air conditioner Model abt45rba3w Serial t000147 The unit will not operate. The red operation light is flashing fast continuously and the a/c unit will not turn on. The timer light is...
Have you checked for compressor operation? If it is not running you may need to replace the hard start relay/capacitor. If you remove it and get the numbers it is available on ebay for a fair price. eBayeBay
Sep 07, 2017 | Fujitsu Heating & Cooling
Flashing red lights
try checking out this website it worked for me. www.epson.com/ipr
May 18, 2008 | Epson Stylus C86 InkJet Printer
Dometic Rooftop RV Air Conditioner Logo
640 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
