Question about Whirlpool 10 cu. ft. / 283 liter Chest Freezer EH100FXKQ
Freezer stop working today and 12 months ago
12 months ago a can of 134a was added and the freezer worked until toay. Some 134a has been added. How do I know when enough has been add? I have a guage connected.
  • 39 Answers
Your low side should read +5psi to 0 psi but not -2 psi. all of your tubing(evap+condenser) coils are inside the walls. it might be under the 5yr sealed system mgf. warrenty
Posted on Jul 14, 2009
How to add 134a to magic chef deep freezer
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Nov 08, 2015 | Magic Chef Chest Freezer MCCF5WBX
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
690 series subzero freezer issue
Richard, what you are doing is ok for afew month. Your system is not broken yet. There could a variety of reasons. Wait until it breaks.
Nov 16, 2013 | Freezers
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My freezer
Be sure your cords in the back are plugged in, and you shut the door completely, if you move the freezer to check if it's plugged in, don't pass out when you see all the lint!
Nov 29, 2007 | Freezers
Freezing
YOU COULD GO TO THE AUTO ZONE AND BUY A TAP VALVE AND FREON 134A CHARGE IT THROUGH THE LOW SIDE SHOULD READ 5 AND HIGH 150 USE 134A. IT MIGHT WORK FOR A FEW MONTHS TO A YEAR IF NOT LONGER BUT YES IT HAS A LEAK THE CONDENSOR IS BUILTIN AND MADE OUT OF STEEL AND IT RUST THROUGH OUT THE YEARS THEY SHOULD OF USED COPPER NOT STEEL
Aug 29, 2007 | Amana 16.8 cu. ft. / 476 liter Upright...
Whirlpool 10 cu. ft. / 283 liter Chest Freezer EH100FXKQ Logo
257 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
