Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Razor screen went blank
By hellllpme on Nov 16, 2007
inside screen went blank and outside screen is blue. i can still call people and recieve calls but i cannot see what i am doing
Same Problem
Nov 21, 2008
-   ******* peice of **** phone first the hinge broke on mine then all of a sudden the screen went black and i couldnt see what i was doing and the phone didnt work at all after that it wouldnt dial-   Guest
Sep 18, 2008
-   What the _uck!!!!!!!! Crappy phone.-   Guest
Aug 14, 2008
-   yesterday morning i pluged it in to charge and when i came back the screen was black on both sides?????
HELP ME!!!!!!!1-   Guest
Aug 14, 2008
-   screen goes white-   Guest
Jun 25, 2008
-   SAME EXCAT THING -   brm0978
Best Solution
posted on Dec 12, 2007
Helpful)
billybotts
Rank: Apprentice
Rating: 90%, 7 votes
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Was this helpful?
Yes
No
Solution #2
posted on Jun 10, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
well i had the same problem and i still do i hit it 3 times on a table and the screen began to show,but it is blury. then turn it off then on again and it is perfectly clear. hope that helped
Solution #3
posted on Jan 26, 2008
Helpful)
Sheena808
Rank: Apprentice
Rating: 85%, 4 votes
Well I just came upon this site b/c my husbands phone was having the same problem for couple of days now and I was looking for help ... even though I found nothing really here, I thought about opening the phone (unscrewing it) then I chickened out just because I'm totally clueless on cell phones (insides) .. but then I got some balls .. found a pair of eye glass screwdrivers .. as I was ready to unscrew it and I noticed that it was alittle unscrewed already .. I tighten it and WALA!!! The screen was in working condition :) I hope this helped someone .. if not .. sorry I tried :D
Was this helpful?
Yes
No
Solution #4
posted on May 03, 2009
Not Rated)
AWARAPAN
Rank: Master
Rating: 77%, 25 votes
Try the link . . . http://www.Motorola.com/Razav3
For find best solution.
26
Was this helpful?
Yes
No
Solution #5
posted on May 02, 2009
Not Rated)
nreu
Rank: Master
Rating: 86%, 11 votes
Having problem with Motorola RAZR V3? Main problem of Motorola RAZR V3 is hardware problem. Such as won't charge, black screen etcFor solution of these hardware problem just click here.
For any other problem of Motorola RAZR V3 like software problem or other just click here.
Was this helpful?
Yes
No
Solution #6
posted on Nov 01, 2008
Not Rated)
mcz_weewee1
Rank: Apprentice
Rating: 0%, 0 votes
I need a solution!!!!
Was this helpful?
Yes
No
Solution #7
posted on Sep 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i was having the same problem with my screen going blank and i just turned on the phone and took the battery out and put it back in and it went back on and the screen showed! it helped me :)
Solution #8
Not Rated)
Mitch2481
Rank: Apprentice
Rating: 0%, 0 votes
hit the back of your cell phone three times on a table and the screen will become blury. then you turn it off and on and it will become perfectly clear.
Was this helpful?
Yes
No
Solution #9
posted on May 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The first time I just tightened the screws on the screen plate and it worked but a few days later it went blank again and now nothing seems to work so I am breaking it down to see what the issue is. I will post my findings.
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
I have a sprint lg rumor and need to know how to down load my photos from this cell phone to my... (More)
Answer
my motorola v3 screen will not light up. the keyboard lights up
Answer
I was given a motorola razr v3a but I don't have the security code. (Just to unlock the screen) how... (More)
15 Other Users Have The Same Problem - Continued
Comment by JR_ANGEL, posted on Jun 10, 2008
outside screen is blue, inside screen is black. tried taking the battery out and the sim card, replaced it but still nothing.
Comment by Avalanche116, posted on Jun 07, 2008
both screen blank
Comment by Guest, posted on Apr 22, 2008
SAME PROBLEM HERE, WHITE SCREEN INSIDE BLUE OUTSIDE
Comment by kmncc, posted on Apr 05, 2008
my problem is the same but a little bit different. the henge on the left side of the phone. the little silver piece came out. so i kept putting it back in then last night. it just went blank. the phone still works because this morning my alarms went off this morning. should I try to use brake cleaner?
Comment by maryrezka, posted on Apr 05, 2008
i can call and recieve call but cant see what im doing
Comment by milo102, posted on Mar 15, 2008
my screen goes white i the phone works perfectly fine but my screen aint working
Comment by EvilDeadAsh, posted on Jan 17, 2008
My screen keeps going white. when I flip the screen back and forth sometimes it will come on..but as soon as a press the buttons on the keypad it goes back white. outer screen is blue..what is the problem? this seems to be a common problem but there are no answers in the answer sections...HELP>>
Comment by Guest, posted on Jan 06, 2008
i can even hear all of the sounds and i have tried filping the phone milllions of times but it wont ever work!!!!!!!!
Comment by Guest, posted on Dec 10, 2007
my screen is showing black, i cant see anything
Comment by papdaddyz, posted on Nov 18, 2007
i have the same problem. for a while the inside screen went white and the outside turned blue, but the usually went back to normal if opened and closed the phone a few times. after a while tho they wouldnt work at all for about a week and a half. then it worked perfectly for 2 days out of nowhere and i had no problems, and then the other day is stopped working alltogether again. what gives?
Describe your Cellular Phones problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Cellular Phone Experts
Top Cell Phone Repairmen
in , TX
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
