Cars & Trucks Logo
Lori Kreklau Posted on Nov 17, 2015
How do you test a motor when you got it out of cart 36 volt
1996 ez go 36 volt golf cart not doing anything. Where do I start?
You need a volt meter the problem is some ware between the battery and the ignition switch .Check battery grounds all if bat is grounded you should have 6.5 v D.C from B+ to anything on the engine or frame one at a time then test both for 13 v at the same time jump them together .This could be your problem 2 battery's with 1 bad ground .Then start from the other end the ignition switch use jumper leads hook to the switch in start position key turned to black to ground see what you have for voltage drop it should be around 12 volts if you have nothing its the ignition switch if you have less then 12 v its likely a bad ground from one of the battery's or something related to the drive motor
I need a wiring diagram
if the wires have been cut but they are still in the harness the the colour of each wire can be paired back up to start with
the rest if any left will be touch and feel what happens
Yamaha golf cart 36 volts last set of batteries get hot awhile driving
batteries will get hot when working as there is current flow across the plates . For batteries to get noticeable hot then there is a current draw that exceeds the capacity of the battery . This indicates a problem electric motor in the system (Worn bushes/bearings -armature poling out --shorting windings or armature) it may also indicate shorting between batteries from a battery that has collapsing cells . Have each battery inderpendently load tested
I have a late 80s model golfcart 36 volt system with 6 cabels can you tell me how to hook them up
GOES LIKE THIS..
CART MOTOR, Positive, Negative, Postive, Negative. Ect... Back to the other side of the Motor
Golf cart wiring
Its been a wile but if I remember right it goes from the solenoid under the cart (pass side) to the key switch (the other wire is probably volt meter) then micro switch,green wires from micro switch to controllern. Inspect all spade connections
3helpful
2answers
EZGO golf cart won't go forward
Your batteries have died. The reason it will barely move in reverse is that current is being supplied to the motor is a direction that it spends very little time using. There is a slight change in the armature over time, and reverse tends to work better over time. Check the voltage when under load. (run jumper wires from the + and - of the battery bank. If it is a 36 volt cart and the voltage drops to below 36 volts, you do not have enoug current to run the cart. Plug in the charger and watch the ampmeter. If it goes up to about 20 amps, then it is charging. It should take a good charge after 10 hours. If the cart charges and only runs a short distance, the batteries need replacing.
48 volt GEM cart That will run fine in turf but not in road mode
replace the voltage controller for the drive motor.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
