Question about Sharp LL173C 17" Flat Panel LCD Monitor
Acer monitor i tried to hook my monitor up today, but the only thing showing is a white screen. not for sure if it is to do with my mb or what. i have 256 mb modem.
0 characters
1 Points
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computer Monitors
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computer Monitors
My acer laptop monitor does not come on but all am getting is a white screen. I hook up the crode for the big monitor to my acer laptop and i can only see on the big monitor......
If you are getting a white screen that means your FL inverter is bad. This is what powers the LCD and displays. I do not believe Acer offers only the FL Inverter to be replaced. I believe you will have to purchase another screen to get it to work. You will have to compare the cost of a new screen vs. the cost of a new laptop. I would suggest taking it to a local show to have testing done on it. It also could be something as simple as a loose cable connecting the screen to the laptop motherboard. Again, I would take it in somewhere where professionals can take a look at it, unless you are comfortable with opening up laptops. Good news... The laptop itself is still good, as you are getting display on an external monitor.
Jun 02, 2011 | Computer Monitors
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
Only 2/3 of screen working
sounds like the lcd monitor is going bad. To make sure though, hook up another monitor to your computer and if the monitor shows a full picture then that means the original monitor is bad.
If your replacement monitor shows a 2/3 screen, then you know its a problem with your video card.
Nov 30, 2009 | Acer AL1721 17" Flat Panel LCD Monitor
I hooked up my new acer p191w to my dell laptop 1525.HELP!
Not sure what the problem is, but I would suggest pressing the Fn+F5? There is a function key that toggles from dual screen, just the laptop screen or just the monitor. Hope that helps..
Nov 11, 2008 | Acer Computer Monitors
Emachine monitor with a HP computer
i am trying to hook up a emachine monitor to my compac computer but the monitor will not come on there is another wire coming off the part that hooks in the compac but there is nowhere to hook it can you help me?
Oct 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Sharp LL173C 17" Flat Panel LCD Monitor Logo
Top Sharp Computer Monitors Experts
 Mike M
Mike M
Robert Rankin
Are you a Sharp Computer Monitor Expert? Answer questions, earn points and help others
