Question about GretagMacbeth Gretag Macbeth Eye-One Display 2, Complete Monitor Color Profiling Solution. Printer
My hard drive crashed and I reinstalled i1 and
My hard drive crashed, after replacing it I reinstalled i1 and when I plug in the USB cord, the test says it cannot find a device
EXACT same problem, I'd love to know if ou've fixed it, and how
Posted on Oct 19, 2009
What to do if it crash
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope it helps
May 15, 2012 | Western Digital 500GB ELEMENTS 500 GB USB...
Dst short test fail
DST Means: Drive Self Test. What happened here was when your laptop booted the Hard drive does a short self test on itself to make sure its still alright. If your drive is not functioning like it should, the test will fail. So needless to say, your hard drive has crashed. To solve this problem you will need to replace the hard drive with any 2.5" Notebook ATA hard drive of your choosing. Then after you have the drive installed the new hard drive, use the disks that came with your laptop to reinstall Windows. If you do not have the disks, you can use any Windows XP CD that you can get.
Apr 11, 2011 | Dell Inspiron B120 Notebook
Computre not reconizing my my book HDD 1TB usb 2.0 but it does power up but when you try to plug the usb cord in nothing happens on the computre it dont even show up under devicer manager
Try an new USB cord. If nothing happens, then most like scenario is the controller card went out on the case housing the hard drive. Easy way to test is open the case, remove the hard drive and conect it to your pc or take it to a repair shop to hac=ve the hard drive tested. Usually, shops won't chare for this. If hard drive is good, pick you up a new external hard drive case.$20 or less online.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817392032
Nov 30, 2010 | Western Digital My Book Essential 1TB...
It keeps crashing after 1 minute or less
test all leads that attach to your hard drive electrical,IDE,SATA,also from your motherboard to your hard drive or just replace them,test your PSU aswell
hope this helps
Aug 09, 2010 | Western Digital My Book Home Edition 500...
I have a mini mac and an external Rock Mobile Disk. It flashed red and green constantly and my computer cannot find it. I have changed computers( another mini) and ubs cords. Rich
Make sure the cable is fitted securely at both ends. Check to see if another usb device works on the same port. If the drive uses a "Y" usb cord (one usb into the drive and two into the laptop) Make sure the replacement cord you use to test is a "Y" cord as well. Open Applications>Utilities>Disk Utility. Check to see if a second hard drive is listed on the left hand side. Is the drive mounted? If not then select it and click the mount button at the top. If there isn't a second hard drive listed you could try removing the hard drive that is inside the case and hook it up to a "IDE/SATA to USB" hard drive adapter and plug it in. Instructions on where to find and how to use these adapters can be found on google. Sometimes the electronics inside the case can go bad and using another case or adapter with the hard drive can make a difference.
Feb 15, 2010 | Computers & Internet
Can't plug the usb plug into the external hard drive.
Sorry, you either need to repair the USB connection or buy a new hard drive.
Jul 14, 2009 | Western Digital My Book Essential Edition...
500gb St ex hard drive suddenly disconnects when still plugged in
please try to check your external hard drive if theres a problem aside on the cord connecting to pc...
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
I cannot read my western digital external hard drive from my macintosh. Was there last week, but disapeared when I started my computer today. Any suggestions?
Unplug the power cord , have your computer boot completely then plug in your hard drive again.
This next bit is a bit unorthodox but as you plug in the power can you hear it spin up ?
if not i think that the power module inside the case is faulty
If it does spin up hopefully your macintosh can detect it now , im not to familiar with macintosh's but i think dirvers are apart of the windows world so either uninstall the drivers (if any) and reinstall if none check the usb or firewire cable is properly plugged in , if so check the usb or firewire cord works by trying it on another device or purchasing a new one and testing it on your hard drive.
If none of that works i suggest you get a replacement on warranty if the data on the disk is easily replaceable , if it isnt you can open the case, remove the hard drive and buy a external hard drive enclosure kit and use the hard drive in that.
Sorry i can't be of more assistance but the macworld is very foreign to me
Goodluck and please don't forget to rate :D
Aug 25, 2008 | Computers & Internet
Toshiba satellite screen blank
This could be that the hard drive has failed, and could also be the reason for the initial crash. Run a drive test in the bios or set up. If the test fails in any area then the hard drive is bad and will need replaced. If it passes, then reformat the drive and reinstall XP.
Jul 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
GretagMacbeth Gretag Macbeth Eye-One Display 2, Complete Monitor Color Profiling Solution. Printer Logo
133 people viewed this question
Top GretagMacbeth Office Equipment & Supplies Experts
jasbo
jasbo
Are you a GretagMacbeth Office Equipment and Supply Expert? Answer questions, earn points and help others
