Question about Brother HL 5250DN Laser Printer
Where is the drum counter reset button on my Brother 5250DN?
    President:
  • 2,306 Answers
Open the front door and press and hold the go button until all lights flash and you're good to go...
Posted on Jul 14, 2009
I have a brother 5250dn printer that's on strike right now. At first it wouldn't print indicating a drum problem. We addressed that issue by resetting the drum counter (took out the toner/drum and held...
Try this.... no guarantees but I have seen this work.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jan 19, 2011 | Brother HL 5250DN Laser Printer
Reset drum life
If you are asking how to reset the drum replacement light then all you need to do is open the front door on the printer. Now press AND hold the GO button and continue holding until all 4 lights on the printer come on. Now release the button and close the front door. This resets the internal drum counter.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | Brother HL 5250DN Laser Printer
Brother 5250dn drum light blinking; I think drum is ok because I put drum from another working printer and the drum light continued to blink.
The drum light is on due to a preset counter to notify you that the drum has reached the end of Normal Usage life expectancy. It doesn't mean that it has failed, yet...but soon. I would suggest having a new drum on hand for when print quality starts failing. Either new drum units have a reset fuse in them to clear the warning light, or there is a reset proceedure to use after installing the new drum unit.
Nov 06, 2009 | Brother HL 5250DN Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Brother 5250DN Printer Toner light
Try resetting the toner counter manually;  * Turn off the printer and open the front cover * Press and hold the Go-button down * Turn on the machine while still holding button down, when all three LEDs are lit, release Go-button * Press the Go-button twice, and all three LEDs should be lit again. * Press the Go-button five times (six times if you have the High Yield toner) * Close the front cover and the toner counter should be resetted.
Jun 02, 2009 | Brother HL 5250DN Laser Printer
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Drum
You just need to reset your drum counter. To do that, open up the printer and hold down the Go button for a few seconds, until the LED lights all light up (the toner, drum, and paper lights all should turn yellow). That should do the trick!
Feb 16, 2009 | Brother HL 5250DN Laser Printer
Toner light Brother HL 5250
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Mar 25, 2008 | Brother HL 5250DN Laser Printer
Brother HL 2040 problem
Sep 14, 2007 | Brother HL 5250DN Laser Printer
Brother HL-5250DN
Sep 01, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
858 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
