Question about Kodak EasyShare Z740 Digital Camera
Keeps telling me to format memory card
When I tell it to format, it goes back to the question and takes me in a circle
  • 36 Answers
The memory card might be bad. Try a new or different memory card and if those work fine, t is your card that's bad. Have you used this card in this camera prior with good results or is this the first time? Has the card been formatted on a different system or different computer prior and if so, there might be problems there and maybe if the card is good on other equipment, it might be relegated to just those. If you have data or photos on your card that you cannot recover yourself, you can try sending it out to a data recovery service you can find online.
Hope this helps, Mike
Posted on Dec 13, 2015
SOURCE:
  • 39 Answers
SOURCE: Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Posted on Nov 28, 2008
SOURCE: My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
Posted on Sep 02, 2009
leepania
  • 1099 Answers
SOURCE: We insert a memory chip into our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 04, 2010
kaimster
  • 87 Answers
SOURCE: TRying to install a new sd memory card, screen
take you card and insert it into your pc. format the card there into the desired form the camera wants. then you can use your card.
Posted on Jun 27, 2010
SOURCE: FORMAT MEMORY CARD
Kodak EasyShare C315
Wants to format card
Filesys error e00100 when formatting
same with another card
Posted on Jul 30, 2010
Kodak easyshare dx7590 will not read any of the memory cards I try to use, why?
This may be camera card slot problem, if you are technician then open your camera and cheak the card slot, most of issue is card slot of camera,
Need more help tell me ,.....
Nov 03, 2012 | Kodak EasyShare DX7590 Digital Camera
Camera tells me "memory card requires formatting."
Your memory card is larger than 2GB, isn't it? The CX7330 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the camera, they are electronically incompatible and won't work in the CX7330.
Dec 20, 2010 | Kodak EasyShare CX7330 Digital Camera
Just pt in a neww sd card it keeps telling me that the memory is full and it wont take any pictures
You must have pics on the internal memory. That's what the camera is telling you. You should format the internal memory with no card in the camera. Then, insert the card and it should work properly.
Sep 10, 2010 | DXG Technology Cameras
Whenever i put a new memory card in the camera it tells me to format the memory card. whenever i press continue it goes back to the format memory card statement. how do i format the memory card
First, be sure the card slide switch is in the unlocked position. Then, insert the card,ignore the message on the screen and go into the camera menu to find "format"...then, follow the on-screen instructions.
Aug 18, 2010 | Kodak EasyShare C315 Digital Camera
Hi all, my nokia 6300 is switching "off" and getting "on" automatically. Please tell me what to do!! Please tell me the format code for nokia 6300. I'm waiting for your reply
If you have a memory card remove it and restart your phone.If the phone works OK now, then format your memory card after backing up the data.Always take care to keep your memory card half empty.
*#7370# is the format code for your phone.
You can format your phone in this way too.
1.Turn off your phone
2.Press and hold *, 3 and green button at the same time.
3.Holding these buttons turn on your phone.
Release these buttons only when the screen shows formatting procedures.
May 09, 2010 | Nokia 6300 Cellular Phone
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Problem with the memory card of Nokia 6600
Connect your mobile to A pc on data transfer mode. Right click on you mobile memory card and format it. Open any folder on your pc go to tools, folder option and then select show hidden files and folders and deselect 02 more hide boxes below it. Now browse your memory card for any unnecessary files or folders, i.e. boot sector virus. comment back if you cannot use your card after doing this also.
Aug 11, 2009 | Cell Phones
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
I hope this helps.
Nov 28, 2008 | Kodak EasyShare C743 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
