Question about Sony DCR-DVD301 DVD Camcorder
Dvd301 no power
Will not power up with or without cord. Replaced battery and still will not power up.
  • rayke Dec 31, 2007
    A completely charged battery pack is installed properly. The POWER/CHG lamp turns green after pressing the power button. However, the POWER/CHG lamp turns off automatically in only 5 seconds.
  • 64 Answers
Needs to be sent in theres a prolem with the main pcb it happens alot. sorry
Posted on Nov 19, 2007
Toshiba nb505 says battery is charging but its not.
By replaced battery, you bought one? Some aftermarket batteries do not work well with your laptop. I would return the battery as defective. Some aftermarket batteries are inexpensive for a reason. Make sure the Cord/charger and the battery are the EXACT same power specs, DC volt and Milliamps, or you may fry components.
Jan 27, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
I always get plugged in not charging when i charge my laptop even when it is not fully charged
If the laptop works fine off the power cord without any problems then your power cord is ok, but if the battery is not charging then the battery is probably dead and needs to be replaced. Batteries only have a useful life, and when it's over they have to be replaced.
If the laptop does not work with the power cord then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop. If either of them is bad the battery will not charge.
Check your DC Power Jack which is where the power cord plugs into the computer. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
My pc battery shows red color when it is on power
If the battery shows a red color and it stays red even when the Power Cord is plugged in, then either the Power Cord is not charging the battery or the battery is completely dead and needs to be replaced.
The battery only has a useful life then it must be replaced because it will not hold a charge.
If you are able to use your laptop with the AC Adapter and Power Cord without any problems then the power cord must be ok and the issue is with your battery.
May 13, 2012 | Dell Latitude D630 Laptop Computer PC...
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
My inspiron laptop wont turn on after I replaced
Verify that you obtained an exact replacement power adapter for the Dell. If it is an exact replacement then try this. Disconnect power adapter. Remove battery. Reconnect power adapter without the battery. If it turns on, then power off and place battery back in. Then try again. If problem returns, there could be a problem with the battery itself.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Dell Inspiron 1501, replaced battery and power cord
Power on the laptop without the battery in the unit. If it powers on, then place the battery in and it will start to charge. Sometime the Dell laptop will not see the battery when it is replaced.
Mar 23, 2009 | Dell InspironTM 1501 Notebook
No juice
Sounds like a battery issue. Try powering up without the battery, just AC. If it powers properly, then the battery needs replaced. If it doesn't then it may be the power supply malfunctioning, or the motherboard.
Jun 19, 2008 | Acer Aspire 5315 Notebook
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Sony DCR-DVD301 DVD Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
