Question about Frigidaire FEF336BC Electric Kitchen Range
We had an electrical storm last night and the power flashed off and back on my stove started making a beeping noise and flashing fi on the temp screen nothing was on it was the midle of the night i had to turn the braker off to get it to stop beeping this is a gallery series stove can you tell me what might have happened
    Problem Solver:
  • 5 Answers
The ERc board is fried. This board will cost you aprox. $125.00
Posted on Jul 14, 2009
My stove has the same problem with a loud alarm for several seconds then post F1 in the clock field, the range still works Thank U.... please help SERGIO SANTANA 7-30-10.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Jul 30, 2010 | Maytag MER5730 Electric Kitchen Range
Washer flashes f 1 and will not start
The range/stove fault code page....
My Range is flashing a "F" something.....what does this mean??
Some terms used on this page...ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction. Oven temperature sensor - What a common sensor or temp sensor looks like.
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic by Make and or problem...hope you find this helpful :-)
A tip for the famous F1 fault code entr_anm.gif The biggest Fault Codes list that I am aware of! What does an oven temp sensor look like?Some info and tips on oven temp sensors
Newer 4 digit fault codes - Maytag, JennAir, Magic Chef Newer Frigidaire fault codes new25.gif Some newer GE built in oven fault codes are here. Newest Hamilton built GE clock fault codes are here. I have some of my own hand written fault codes, here and some more here. The Maytag Gemini range fault codes are on this page. The Maytag Accellis range codes are on this page. traffic_record.php?lc=024041009290002517 A tip:The supplier recently reversed the display areas for the clocks. Therefore you may find an F1-E0 code or E0-F1 code depending on the model. They both mean the same thing, and depending on the model determines the code reference, and location of the F code. Different manufacturer of the clocks caused this.
Mar 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It displays F1 . Is this a fuse problem and where is the F1 fuse
HELLO THERE
Feb 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven door is locked after the self cleaning and I cannot get it unlocked. I have had to cut the power to it last night - tried several times to start it and pressed the clear and clean and clock...
Solution - A service man came over and he took off the back of the central part of the stove and there is a small motor there and he removed it and turned the long metal rod that locks the stove and turned it so it would unlock the stove. He then replaced the motor with a new one. This will cost me some money but just finding the way the door locked was good to know.
Feb 01, 2010 | Frigidaire FEF336BC Electric Kitchen Range
F1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
Jan 12, 2010 | GE Profile JTP56 Electric Double Oven
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Amana acs7270ax stove beeping and flashing panel
The F1 error code indicates a control board failure. You need to replace the electronic control board. Good Luck Please rate
Dec 18, 2008 | GE Spectra JBP78 Electric Kitchen Range
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Xbox 360 freezes
There are some recalls on this unit. Call microsoft for help.
Dec 13, 2007 | Microsoft Xbox 360 Console
Beeping noise - letters appear fc
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Frigidaire FEF336BC Electric Kitchen Range Logo
206 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
