3 bars are showing every time I turn on the TV. They go away about an hour after it has been on. What can I do?
    Problem Solver:
  • 6 Answers
Most likely u have a capacitor going bad.
Posted on Jul 14, 2009
TV Rarely Starts
Check all the solder terminal at its main power regulator section circuit. Any loose solder terminal can poise this type of problem. Resolder all the suspected solder terminals by applying a little more solder. If you wish to get more details, check this site.
Apr 22, 2013 | Hitachi 32UX01S TV
The menu screen will not go away!
Try to push the menu button on the tv itself numerous times and see if it will go away (since the buttons are not used often they become resistive and it could be any button,if that dont fix it then the main digital board is bad.
Mar 19, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Mitsubishi ws65711-Volume bar always displays/remote not working
Just solved my problem. Found out that the down volume button must have been sticking. Tapped on it a number of times and finally the volume bar went off and then the up volume worked fine. Looks like the down volume button on front panel is intermittently getting stuck. This happened last year but went away before I could figure it out. Maybe going to try and blow some compressed air in button socket.
Jan 25, 2009 | Mitsubishi WS-65711 65" Rear Projection...
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
LARGE BLACK RECTANGLE BAR BLOCKING TV SHOWS -- WILL NOT GO AWAY
It sounds like the closed captioning background.
Press Menu on the remote
Press Up or Down, Ch + or C- to get to Closed Caption
Press right side button or Vol+ and Mode will be highlighted
Press right button or Vol+ until it says Off on the right hand side of the Menu
Press exit and that should do it.
Hope this helps.
Oct 17, 2008 | JVC AV-27D303 27" TV
Thin blue line
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Mitsubishi rear projection tv problems
this problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Feb 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Sony kv-34xbr800
I have the same problem. When using the remote, it makes the clicking sounds like it turns on, then immediately makes the clicking sound of turning off. The LED blinks repeatedly 6 times over and over.
I *did* get it to come back on by holding the power button down for about 5 seconds. Now I'm afraid to turn it off again! :(
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
