Question about Maytag Ovens
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
  • Anonymous Mar 12, 2014
    why does it take so long to pre-heat my gas oven?
I did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Posted on Oct 31, 2009
General electric stove not heating up
check the oven temp sensor located in the oven cavity in the upper left corner,at room temperature it should read 1100 ohms
Sep 28, 2012 | Stoves Ovens
Oven is taking to long to heat
look for the temperature sensor inside the oven cavity in the upper left or top center of the upper oven cavity,its will be a silver or copper colored rod about 1/4" by 2" to 6" long this rod senses the oven temp and cycles the heat to the oven
Jun 03, 2012 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven not coming on
Do you have a flame sensor located next to pilot lite if so remove and replace at your local ace hardware store remember to turn of gas and electric is repaire are attempted. Next if no flame sensor your termostate sensor located in oven is the problem and must be replaced there is not test for that one just remember that connections are located on the top section of stove and always check fuses if equipt.
Mar 11, 2012 | Maytag Ovens
My maytag gemini ovens will not heat up, It seems strange that they both do not heat. this is a gas stove and have never had a problem.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Ovens
My Maytag Gas Oven will not heat up very much. It's a 50/50 guess if the oven will heat to the correct temp. Sometimes it works fine, the other times it is not very warm at all in the ove, even after...
ello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Maytag CWG3100A Gas Single Oven
Maytag 30" PGR571DBDQ stove. Oventook over 30 minutes to reach 350 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 13, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Model # fgf347awj propane oven will not pre-heat.
Sounds like gas valve is bad and the thermostat also. I would change the gas valve first. But when you said oven would not lite sure sign the gas valve is bad. New gas valve is about 50ish t-stat could be another 20. I would almost just get another gas stove at a used appliance store for 125 or something like that if unit is very old.
Nov 25, 2008 | Ovens
Oven Stops Heating
try it on broil and let me know what it does i dont think its a sensor as they check their selves and set a code most of the time
Feb 15, 2008 | Ovens
Open Questions:
Ovens Logo
326 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
