Question about Philips 50PFP5332D 50 in. Plasma Television
Tv won't come on.just clicks and clicks and clicks.blue power light is on but it won't ignite and come on.
  • 10 Answers
I have the same tv and the fix was the power supply board that had 5 capacitors that were blown. there was a black goo on the top of the capacitors. The power supply board is in the middle top of the tv once you pull the back off. replace the bad caps and you should be back in business. My 50 inch plasma fix costed $5 in parts (5 capacitors) and $9 in shipping fees. Much better than the repair shop. If you know someone who can solder for you or if you can do it yourself, it's very easy to fix.
Posted on Jul 22, 2009
    President:
  • 1,077 Answers
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
My goodmans tv switched itself off and won't work
Make sure that the electricity is working
Make sure that every connection is in place the
scart connection as well.
Disconnect and wait for 2-5 minutes
and connect and start.
If that does not work look for troubleshooing in the manual or click on the name of your TV here at the top of the page.
good luck
kolbrun
Aug 11, 2011 | Goodmans GTVL32W27HDF 32 in. LCD TV
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Model: HD - Z70RF7 projection TV Lamp has blown. I have replaced with brand new lamp and now get rapidly flashing orange lamp light on front of TV, blue power light is solid and not...
Tv turn on now,hear alots of clickings too?Yes.Check the Ballast board,this board might be dead too.The ballast board job is,just it to help to ignite the projection lamp.
Oct 28, 2010 | JVC Televison & Video
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Philips 50PFP5332D 50 in. Plasma Television Logo
333 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
