Question about Linksys WRT54G2 Wireless Router
Cannot connect both XP computer and Vista to Internet
My XP computer connected through the cable modem just fine alone. When I added my new Vista pc and WRT54G2 Wireless router, I can get local network access only. The XP pc can go online, but the only way the Vista PC can access internet is if I connect it directly to the modem. What's the point of having a router if it doesn't "route"?? I have spokent to Linksys support twice, Dell Support once, and after two months, it STILL doesn't work. Can't anyone give me a straight answer?
  • Dick
    Dick May 11, 2010
    I'm suspecting you'll need the ID ten-T form from Linksys to solve this, but let's give it a try anyway. Are you attempting to connect your Vista computer to a wired port of the router or the wireless? Have you instructed the router to only allow connections from a particular MAC address, or is the router wide open? What are the security settings on the router, do they match your Vista settings? Is the XP computer wired or wireless? Can you connect to the router with both computers via the browser interface?
  • 339 Answers
A lot of cable modems will store the MAC address of the first device connected to them and will only talk to this particular device/MAC address. If this is the case, you will need to power down the modem and the router for some period of time. If you also get phone service through your cable company then there may even be an internal battery backup that you have to exhaust. Unplug it and wait at least one minute after all lights are off and then turn it on first followed by the router. The router should then register its MAC address with the modem and then all will be good.
If your modem or some other equipment owned by the cable company permanently stores the MAC address then you will need to one of two things. The easiest is to call the cable company's tech support and ask them to change the MAC address for your account to match your router. The seoond option is to configure the router to clone the MAC address of your XP box. Here is a link to a thread on linksys' web site with step by step directions:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=108261
Note: If you want to implement security, do not use WEP as indicated in these directions, use WPA. WEP is hardly better than no security.
Posted on Jul 14, 2009
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Delete wireless program on emachine
When the router was removed, did you restart the cable modem (power cycle it) with the computer plugged in. This will refresh the IP address on the modem and probably fix the issue.
Reboot the computer.
Change out the ethernet cable between the computer and modem, they can go bad unexpectedly.
You also might check device manager to see if the ethernet port has any issues.
Finally, just because I have seen it happen, make sure you are using an ethernet (larger plug) and not a phone line (small plug) to connect.
If none of this helps, please add your operating system (windows 7, vista, xp, ect), so I can tell you were to look for other issues.
Feb 02, 2012 | E-Machines Computers & Internet
We have two computers and we are trying to set up a network so both computers can use internet, the host computer has windows vista and coble modem the other computer has windows xp and is about 275'...
Hi.
You are going to need two things for this to work.
First, you need a wireless router, these usually run about $50-$60.
Then after you get the router, you need a wireless usb adapter, so that the xp computer can receive the signal from the router.
Connect the lan cable from the cable modem that is currently attached to the vista computer to the router, then connect a lan cable from the router to the vista computer.
The xp computer is easier.
After you have the router hooked up, just plug the usb adapter into the xp computer, install any software that comes with it, and after it install the drivers it will be able to connect to your router, and have wireless internet.
Make sure that you know the name of your router, that way you are connecting to the right one.
I hope this helps you out, and have a good day.
May 21, 2011 | Microsoft Windows XP Professional for PC
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
How do I migrate my internet connectivity from an old pc running xp, using isp comcast & Thomson cable modem over to a new pc running vista?
NOTHING.
turn off all equipments.
connected the modem to the incoming cable.
use the CAT-5 cable comes with unit, conencted from the one of LAN port to your PC LAN port on the rear panel. turn on the modem then turn on the PC.
you are good to go.
Dec 18, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Bought a new computer with vista instead of XP and cannot connect to internet via the ethernet line from my cable modem. what is the secret? Usually plugging it in is enough when I have moved or changed...
Yes! plugging it in on the Ethernet cable on the modem to the computer should get you online. If your not able to get online, you may want to check the following:
1. Make sure that the Ethernet adapter on the computer is enabled. If you can't find the Local Area Connection icon in your Network connections (control panel\network and sharing center), check if the network adapter is properly installed.
2. Some cable service providers require the MAC/Physical address of the Computer to get it online through the modem. If the old computer is working with the modem, you may want to contact your ISP and ask their assistance in getting you online using your new computer.
Aug 02, 2008 | Gateway Computers & Internet
Connect the lg mobile to pc
HAI,TO CONNECT INTERNET THROUGH CABLE OR BLUTOOTH.
(i) 1.CABLE : INSTAL DRIVERS FOR THE CABLE AND LG PC SUITE,RESTART PC THEN CONNECT DATA CABLE BEDWEEN PC AND MOBILE.IT,S ORIGINAL CABLE DRIVERS ARE AUTOMATICALY INSTALED,ORDINARY CABLE MANUALLY INSTAL DRIVERS.
2.THEN FOLLOW TO CONNECT INTERNET:
   START>CONTROL PANNEL>SELECT NETWORK     CONNECTIONS>SELECT CREATE NEW CONNECTION>FINISH.RESTART PC AND THEN CONNECT INTERNET THROUGH NEW CREATED IN NETWORK CONNECTIONS.
(ii)VIA 1.BLUTOOTH:INSTAL BLUTOOTH SOAFTWARE(BLUE SOLI) AND RESTART PC.
2.ON BLUTOOTH ON MOBILE AND CONNECT MOBILE TO PC (BLUESOLI).SELECT DUN INTERNET CONNECTION TO INTERNET.
Jun 30, 2008 | Computers & Internet
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
I cannot run internet with my router
downgrade your vista to windows XP Pro or XP home..
Nov 07, 2007 | Belkin (F5D8231-4) Wireless Router...
Vista/router/wireless connection
Make sure that all the wireless cards are set in the properties to obtain an ip address automatically, dissable the wired lan adpter connections as this can confuse the router. Restart all the pc's and then right click on the wireless pc icon in your task bar and then click view wireless networks and make sure that you are connected to your network and that the internet is available, known as local & internet in Vista. open up internet explorer, go to tools, internet options and delete browsing history cookies and temp files and then refresh the page as the proxy server will need to refresh.
Sep 24, 2007 | Computers & Internet
Linksys WRT54G2 Wireless Router Logo
251 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
