Question about Refrigerators
The ice maker is not working on Model # JCD2389DT
The ice maker is not working. How can this be fixed?
  • Refrigerators Master
  • 4,654 Answers
  • 1 more comment
  • John Tripp
    John Tripp Jul 14, 2009
    Sorry to need to ask but I just have a very little to go by to answer your question without guessing.There are close to 70 models of (JDC model prefix) JENN-AIR Model Refrigerators. Can you take a digital photo or get me the model number or tell me more like water will not fill, Dispenser light no on or water works and ice maker don't work. Then Contact me at appliancepartsse@yahoo.com to send a photo. Thanks, For Understanding, Sea Breeze
    http://servicepartstec.blogspot.com/
    http://appliancepartseast.blogspot.com/
  • John Tripp
    John Tripp Jul 15, 2009
    The most likely problem is the water control valve on rear of refrigerator. Do you have an ohm meter? Let me know if you still need my help. I would like to be the one to help you get it fixed. Sea Breeze
  • John Tripp
    John Tripp Jul 17, 2009
    The most likely reasons for the ice maker not working is the water control valve on the rear of the refrigerator is defective or the thermostat inside the ice maker is defective. Look for the model number in these places and I can tell you the part numbers and parts and how to fix. Sea Breeze
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
My ice maker model RS2545SH does not work I could not locate the reset button How to fix please
Have you checked the temperature, inside of the freezer? It must be at least, 0 degrees, before the water will freeze into ice. Is the ice maker getting power? Why do you need to find a reset button? I don't know your ice maker. I've never heard, of a rest button on an ice maker. Your question isn't specific enough. Other than that, I can't help you. Good luck.
Sep 07, 2014 | Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Siemens Refrigerator model KA58NA70NE The ice maker section is not working. Please advice how to fix it.
I had the same problem and fixed it by changing freezer fan found underneath the freezer inside body, just behind the ice delivery/crusher motor. You need to open all the inside upper components like ice dispenser, ice maker, ice crusher motor, lamps assembly and finally the rear upper inside body cover. First, check whether or not the fan has strong air ventilation before trying to change the ice maker fan motor.
Feb 04, 2011 | Siemens KA62DV50GB Side by Side...
Ice maker leaks water
Good work thus far. If the ice maker tray that holds the ice is leaking, you need to get a new ice maker. It would never work right if you tried to patch it, and would only cause further headaches. Sounds like you have a little experience which is good. Go down to a local retailer and purchase an ice maker and install it yourself instead of paying someone to do it ;) There is no foul in paying to get it done though. good luck!
May 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker is not working
Try this, pour tap water into ice maker and let freeze. If it dumps after freezing and does not refill with water it will point to water control valve. If it does nothing then the ice maker has the problem. I am really not sure what model or style of Pofile so I will need your model number to find part numbers and locations. Most profiles have electronic ice makers and if they go bad there are only a few fixes on some models depending on model number. Sea Breeze
Mar 19, 2010 | GE Profile Stainless Bottom-Freezer...
G e refrig. ice maker not working Model #pss26msrdss
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
kk
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker isnt making ice
Be patient.
See if you still have this problem tomorrow.
Mar 31, 2009 | Kenmore Refrigerators
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
