Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Dish Network 625 - how to install and get it to work on 2 tv's. We have one working, need directions on how to get it to work on another tv as well.
  • 374 Answers
On the back of the receiver there is a port labeled IN HOME DISTRIBUTION. Connect a coax to this port and the other end to the other TV. You will then need to put the other TV on 60 air or 73 cable and go back to the original TV with the receiver and using TV1 remote press MENU - 6-1-5 and change the TV 2 OUT to the station you have the other TV on. Now select done and you should have a picture on TV2. eNSURE THE ANTENNA ON THE BACK OF THE RECEIVER IS ELEVATED TO HIGHEST POSITION.Thanks for using Fix Ya.
Posted on Aug 16, 2009
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
Will dish network 510 receiver work in uhf with dish 21.1 remote
No, the 510 receiver does not have a UHF input. http://manuals.solidsignal.com/DVR510.pdf You can upgrade to a 512, 612, 625, but would need your installation upgraded to be compatable (Dish Pro to Dish Pro Plus).
Sep 03, 2012 | DISH Network 322 DTV Receiver
Turn off and on, blue screen
Hi, I am sorry you are having a problem with your DISH video. A blue screen means you are on the correct channel or input on your TV. If you turn the Tv off and then back on, ehat channel ot input does it say it is on. You should be on channel 3 if at TV1 or 60 or 73 if at TV2. If the receiver is connected to the TV using the Red/ White/Yellow cables, then the TV needs to be set to a video input. If you any additional assistance, please email me directly. Thank you!
Mary Catherine Brady
DISH Internet Response Team
marycatherine.brady@dish.com
2:45pm-11:15pm (MST) Tuesday-Saturday
Jun 03, 2012 | DISH Network DVR-625 DTV Receiver /...
We recently moved our dish ( we are in an rv) and now we get a signal on one tv only. we have dish network and a 625 DVR. we have moved many times and have never had a problem before. in order to switch...
5shades690,
Are you still having problems with your TV 2 off the 625 receiver? You have a cable off the back of the receiver, TV 2 Home Distribution. That's feeding to your TV 2 location. You might check to make sure it is secure. You can also see if that cable screws into a diplexer if it is being back feed through the satellite cables. These are all potential problem spots, especially since you said it was working before. I hope this helps.
Ray Calo
DISH Network
Jul 28, 2010 | DISH Network DVR-625 DTV Receiver /...
I have a dish 625 box and duo tv's. #1 remote works everything, but remote 2 will not turn tv on or off or control volume. Tech did have both of them working originaly but we had some issues and now cannot...
grandygram,
I have provided a link on programming your TV 2 DISH remote to your Philco TV. Here is the link:
http://www.dishnetwork.com/SupportSection/remote-setup
The steps are towards the bottom of the page. The codes that have the highest success rate are listed below.
566, 653, 654, 655, 656, 659, 660
I hope this helps.
Ray Calo
DISH Network
Apr 23, 2010 | DISH Network DVR-625 DTV Receiver /...
I hav a duodvr 625 but its olny working for one tv how do i get it to show up on the other tv?
I will assume it was installed to two rooms when installed otherwise it will need to be wired to the second TV.
If it was indeed installed to two TVs at the first tv location with the TV1 remote press MENU-6-1-5. You should now be at the modulator set up screen. Note what channel TV2 is modulated to generally 60 air or 73 cable.
Now go to the TV2 location and run a cannel search. If it does not find the channel go back to tv 1 and change the TV channel to the opposite setting of air or cable based on what it was previously set to and try the channel scan at TV2 again.
If it still does not pick it up then most likely it is not wired for that room.
If the receiver was installed to one location Dish will need to wire the second location for you in order to achieve the desired outcome.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 24, 2010 | DISH Network DVR-625 DTV Receiver /...
Dead unit
I'm sorry to hear about your DISH Network DVR-625 receiver. If you don't mind me asking & to allow me to further assist you, what exactly do you mean by "dead unit"," For example, was it working and has suddenly stopped working? Does it power on, can you see any lights on the front of your receiver? Is it plugged directly into a electrical outlet on the wall, or is it plugged into a power strip/surge protector? If plugged into a power strip/surge protector, please attempt to bypass by plugging the receiver directly into an electrical outlet- if plugged into an electrical outlet please try a different outlet. I hope these few tips may help but if not and you need further assistance please feel free to contact me @ Kirstie.Filosa@Dishnetwork.com :)
-Kirstie DISH Network
Oct 03, 2009 | DISH Network DVR-625 DTV Receiver /...
I want to record to a external hard drive in order to take to Ira
If you have a dish network system as listed in post a DVR 625 this is NOT possible, it will only work with VIP series Dish Network recivers. and they must be used on teh same model reciever such as Vip 722, tranfer to EXT HD then Watch on another 722!
Jun 18, 2009 | DISH Network DVR-625 DTV Receiver /...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
344 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
