Question about GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser
How do I remove the front panel to access the ice chute from the front
  • GE Master
  • 1,606 Answers
The panel approx 4x6" is removed by pulling or prying the bottom of the panel outward . Remove the 3 plugs and then remove the 4 screws in each corner of the "plate" . First I would suggest to unplug the door to cabinet receptical , so there is no power to the door .The rreceptical is either under the top freezer door cap or behind the bottom kickplate .
Posted on Jul 14, 2009
I can't wake my Xerox Phaser 6280 from sleep mode.
The Electronics Module may be faulty but first, unplug the unit from the wall for 30 minutes. Plug it into the wall and see if it completes posting and messages display on screen. Console Panel ZNN (Control Panel) 848K19391
Control Panel (PL1.2.16)
1. Remove the Exit Out Chute (listed below)
Note
Be careful not to drop the Control Panel.
2. Disconnect the Control Panel connector P/J220.
3. Release the 6 hooks securing the Control Panel to the Front Cover
(PL1.2.9).
4. Remove the Control Panel.
P/J220
s6280-181
Exit Chute
Exit Out Chute (PL6.1.1)
1. Remove 2 screws (10 mm, flanged) securing the Exit Out Chute to the
Front Cover.
2. Remove the Exit Out Chute from the Front Cover.
s6280-217
Mar 17, 2014 | Xerox Phaser Office Equipment & Supplies
Frost is forming around the ice despenser inside the freezer and ice will not dispense
The ice chute solenoid located behind the main control panel for the ice and water is bad. Snap the cover off the front and then you will see 4 screws holding the housing in place. Remove this and you will see the solenoid. Replace this and you will be good to go.
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to get ice dispenser panel off front of door?
if its a whirlpoo at the bottom of the trim there are two slots use a flat head pull down and pry out
Jan 21, 2010 | Whirlpool Freezers
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
The ice dispenser chute sticks open allowing warm air into the freezer. Once the chute sticks open, you have to reset it manually but sticking your hand into the ice chute in the door.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 15, 2009 | Refrigerators
Water leaking from behind ice chute door & freezes under ice bin
You will have to remove the unit and access the rear of freezer. Check that the filters are not plugged as well as drain.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser door flap does not stay shut
IS IT A GE? GE HAVE A PROBLEM WITH DOOR SOLENOID IN CUP CHUTE RUSTING,GET A FLASHLIGHT AND LOOK UP THERE,IF IT IS RUSTED YOU WILL HAVE TO REMOVE FRONT PANEL AND REPLACE IT,THANKS-MIKE
May 30, 2008 | Refrigerators
Needs instructions to remove the front panel to replace the microswitch near water dispenser arm
Kenmore model#10658562891 side by side refirigerator.
Need instructions on how to remove front panel to check or replace the heater that keeps Ice from freezing in the Ice chute.
Jan 04, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
ICe does not fall from KitchenAid KSCS25INSS00 Ice Dispener
remove the bottom tray that you sit your glass on, push down on the bottom of the trim arround the despenser, lift outward then upward on the trim panel, have a piece of duct tape handy to tape the panel out of your way to gain access to the assembly
Jan 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
860 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
