Question about Bosch Home Security
Someone piched a part of our security system (a remote power socket unit) and even though it has been reinstalled the alarm beeps annoyingly every minute and flashes fault. what do we do?
    Problem Solver:
  • 17 Answers
Try reseting it with the admin code or the master reset code.
Posted on Jul 30, 2009
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Apr 02, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My alarm wont beep and the remote starter stop working
Check the units fuse if that's ok you may need to replace the alarm devise...
Dec 02, 2013 | C3RS603 2Channel Remote Start Module with...
How to program 473v remote
Open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
Sep 16, 2013 | 5101 LE 1 Way Car Remote Starter System
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
I have a new prestige APS-57C remote starter installed in a 2009 Hyundai Santa Fe and I have a problem with the factory alarm going off every once and awhile. The majority of the time everything is fine,...
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Jan 25, 2011 | Prestige Remote Start
I have an old Westinghouse Security Systems that keeps alarming every 15 minutes Model XL4600SM Key pad and its driving us crazy.. don't know how to shut it off can someone pls. help us (numeros days...
Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
Dec 15, 2010 | GE Security Simon 3 Wireless Home Security...
Out of range issue on viper 3002
I am having this same exact problem. Have you found a solution to this problem yet?
May 16, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Someone programmed their remote into my Bulldog 2010 alarm brain and is deactivating my alarm and then vandalizing my car. How do I get rid of their programming instructions and neutralize their remote?
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Dec 17, 2009 | Basic Remote Vehicle Alarm System
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Please recommend good alarm + remote starter installer in NJ area
Stick with Viper no matter the price even if you have to get a mocel with less features they never wear out  and 99% of problems aren;t from the product but from the installer whereas with cheaper alarms if you have a problem 99% of them are the product.
Apr 11, 2009 | 5900 SST 2-Way Security System / Remote...
Home Security Logo
318 people viewed this question
Top Bosch Home Security Experts
 Russ Hill
Russ Hill
Mohamed Helmy
Mohamed Helmy
Are you a Bosch Home Security Expert? Answer questions, earn points and help others
