I have a toshiba laptop a210-st1616. recently it would not load a computer guy told me that toshiba has a lot of problems with heating up. I would like to know if there is anything I can do myself to fix it since it is out of warrenty
  • 2,418 Answers
Many things cause a computer to not start up once in a while. Viruses, new software issues,
new hardware issues, but heat will cause it to shutdown, get lazy or slow, lock up, multiple images on the screen. One thing you can do is ck your BIOS settings, Press DEL. or ESC as it boots. Check your settings. Save the set up defaults, that should be safe.If you think its a heat thing, B-buy sells a laptop cooling pad, you put under your labtop to cool it. Always ck for viruses, and unwanted spywear.
Posted on Jul 14, 2009
Toshiba satellite A210-19T just updated but laptop will not boot up just says 3 of 3 updates configuring please do not turn off your computer
when starting your laptop togglr F8 key and then start in safe mode and then go to system restore and pick an earlier date and follow instructions
Jan 18, 2013 | Toshiba Satellite Pro A210-EZ2202X...
Can I use a Toshiba recovery disk for A210 series if I have an A505 series? They are both Windows Vista
That is about the only thing thew same about them other than the name Toshiba. The A505 is an Intel Processor, the A210 has an AMD processor. They have completely different video graphics chipsets, audio, and LAN configurations, Assuming that the A210 disc will load in the A505, you would not get proper video, audio or LAN drivers. Recovery disks are made for the machine they are bundled with. You can try, but don't be surprised if your result is less than optimal.
Jan 06, 2012 | Toshiba Satellite A505-S6034 Laptop...
After formating WINDOWS 7 I need to download camera software for A210 laptop,where find this online,thanks
You will find all the drivers for the Toshiba A210 laptop at the link below, if there is no driver listed on the website for your operating system (Windows 7), then it is likely that the camera is not compatible with the new OS.
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
Aug 09, 2011 | Toshiba Satellite Pro A210-EZ2203X...
Just recently had my comp fixed and when i got it home couldn'd get into it ,it was displaying need a password took it back to tech guy and was told that there was some sort of problem with those comps i...
I looked at you model laptop at Toshibas' website and, apparently it has to do with the bios and an update. It says it can happen anytime and if you catch it before this happens, you can do the update and aviod the problem but, if you all ready have the problem, which you do, then you should take it to a "toshiba repair center". I would take their advice and get an estimate on the repair. It was covered under warranty until December of 2010. Check with Toshiba and maybe you can get them to fix it for free.
Apr 04, 2011 | Computers & Internet
My Toshiba Satellite A215-S7444 turns off everything anything type of video is playing internet or dvd. Why is that? What can I do to prevent this?
I'm gonno bump this as it's a massive problem with Toshiba laptops and so many peoples questions are unanswered. I have a Toshiba Satellite A210-11p with an Ati mobility radeon 2600hd graphics card. I have spent years dealing with this problem. Some people will have heat problems, this is a common problem with them, but some laptops will cut out when you go to play say a video or play a game. This is a graphics card problem!! nothing else it is purely a graphics card problem, the second you go to load something when Maximise Performance on the graphics card turned on the laptop will cut out like it shorts out. the charger light on the laptop will flicker and it will make a clicking sound when it cuts out.
Can someone please find a reason and a solution to this extremely common and fatal flaw in toshiba satellite laptops
Jun 19, 2010 | Toshiba Satellite 1805-S274 Notebook
My toshiba A210 laptop will not power up all neons lighting wont power up with or without battery
It looks like you are saying that you can't power up the computer at all.
First, check the power adapter to see if it is putting out the voltage it is supposed to--about 18 volts.
If it is putting out the voltage and you hook it to the computer, your battery should charge and the computer should start. If it does not, then you have a bigger problem. It could indicate bad memory (but probably not, as there should be some flashing of the lights on startup) or a motherboard problem.
Feb 08, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba Satellite A210-11p.Screen is blank.Does
Take a flashlight and shine it into the screen once PC is powered up. If you can faintly see your computer booting up in the background you probably have a bad LCD inverter card. They go for under 10$ on E-bay. Cheap and easy fix if that is the problem. Good luck, Todd
Dec 22, 2009 | Toshiba Computers & Internet
hi my name is gary and i will try to help you with your problem
first of all have you recently added any new hardware to your pc i.e graphics card ..sound card if so start up in safe mode then remove the driver using the add and remove feature in the control panel......if this was the cause of the problem it should now ok
Sep 21, 2008 | Toshiba Satellite Pro A210-EZ2202X...
Wireless network disconnection sometimes
The Toshiba Satellite A210 has a built in wireless adapter - at least all of the ones I did a quick check on the specs. If yours has a built in wireless why are you using an adapter??? Presuming you have a good reason - have you gone in and disabled the built in wireless? They could be conflicting. Second I would use Network Magic software to setup your home network. I struggled many hours and could not get everything to work the way I wanted - all problems with home network fixed in minutes with Network Magic. I do not work for them or anything but I will tell you it is the best software money I have ever spent - and I have been around since 10MB was a dream hard drive.
Dec 31, 2007 | Computers & Internet
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
