Question about Elite Pride Go Go Traveller Plus Electric Scooter - 3-Wheel - Heavy Duty
The scooter stops and just beeps - Elite Pride Go Go Traveller Plus Electric Scooter - 3-Wheel - Heavy Duty
Clean choke and dry for some time and again check current suppliis
Posted on Jul 14, 2009
Hi, this scooter is about 18 months old from new.it now goes, then jolts to a stop beeping its stopped then two beeps
Hi Robert, what is the name of the scooter ?
Is it a small one you can put in the boot of a car ?
Pride Go Go ?
Regards
Rob
Aug 03, 2015 | Health & Beauty
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
How do i permanently stop the beeper on my pride mobility Go Go Sport 4-wheel scooter?
That cannot be done because it is a safety feature of the scooter. If you're saying that it beeps continuously because of the flat battery, that indicates the battery may not hold its full charge and need replacement. if you remove the beeper you will not be notified when it's time to charge the battery. When the battery is charged, does it discharge faster than when the scooter was new? If so, then you need a new battery. Replace it and see if the beeper stops. If the existing battery is fully charged, does the beeper stop? If so, all is well, it's the battery issue. If it doesn't stop beeping, you have to take the scooter to an authorized agent to rectify the problem. I believe the battery is reaching end of its life.
Dec 28, 2014 | Pride Go-Go Sport 4-Wheel
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Random stop then beeping
Hi, when it stops and starts bleeping , Do you turn it off and start again or does it just go again ?,,,
Regards
Rob
www.gewizrepairs.co.uk
Feb 19, 2014 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
My scooter was left in the rain and the horn wont stop beeping do i just let it dry ou and it will stop?
You may have future problems try and get a cover to stop the rain from getting into the scooter
May 18, 2010 | Health & Beauty
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
Feb 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Elite Pride Go Go  Traveller Plus Electric Scooter - 3-Wheel - Heavy Duty Logo
123 people viewed this question
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
