Question about Vizio L32 32 in. LCD HDTV
Our vizio won't turn off or on by our remote. However, we can change channels with our remote. Any suggestions?
    Novelist:
  • 133 Answers
Possibly the on/off button is faulty (worn out) - you can test that by using the camera on your mobile phone (it shows infrared light as visible light). Just turn your mobile's camera on and try pressing the buttons on your remote while pointing it at the camera lens. Now, watch the display on your mobile phone and press various buttons on your remote - you should notice a greenish (or so) flash each time you press a button that works well. As for repairing a faulty button, you can either:
A) buy a new remote
B) cut the conductive pad off an old remote's button and glue it onto your remote's button (this procedure is kinda delicate)
C) buy remote repair liquid and apply some onto the well cleaned contact tab of the faulty button (you'l' need to disassemble the remote for that)
D) make your own repair liquid by mixing some rubber glue (a few drops), some graphite from a pencil core (smearing it with fine sandpaper), and some strong solvent (benzene, trichlorethylene, tetrachlorethane or similar, but in this case you must experiment somewhat with glue/graphite ratio to achieve the right amount of conductivity.
I trust you'll choose the option that suits you most - i've been using a homemade repair liquid and it worked well for quite some remotes i've repaired - just make sure to clean the contact tab well before apllying a single layer of liquid with a single stroke and let it dry.
Don't put on too much - it might stick to the contacts on the lower board and short them - this may cause your TV to "turn off by itself" or other buttons might cease to respond.
Sorry about this lenghty disclosure, but i hope it helps you in some way.
regards
3rq8 (Triarcuate)
Posted on Jul 14, 2009
My vizio hd tv would not turn off the other night with either the AT&T remote, Surround Sound remote, nor the actual Vizio tv remote. I ended up having to hit the switch to off on the power bar. It has worked fine turning on/off since.
Posted on Aug 15, 2010
  • 18 Answers
SOURCE: vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Posted on Jan 23, 2011
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 13 Answers
SOURCE: vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Posted on Apr 19, 2009
  • 8457 Answers
SOURCE: Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Posted on Jan 13, 2010
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
I LOST MY REMOTE TO MY 39INC VIZIO FLAT SCREEN T.V. MODEL D390-BO HOW DO I CHANGE CHANNELS AND ADJUST VOLUME MANUALLY?
Unfortunately, the Vizio D390-B0 only has a Power and Input button on the TV. You need a replacement remote (XRT020) or a universal remote with the code for Vizio that was programmed 6 months after the TV was released. The D390-B0 documentation suggests that the TV was released in 2014.
I hope this helps.
Aug 14, 2015 | Vizio Televison & Video
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Mar 25, 2011 | Vizio 42 in. LCD TV
VIZIO GV42LFHDTV10A loud tone/buzz frozen function
I bought the same TV for my Mother last Christmas. She is having the very same problem. If you have come up with a solution, please let me know.
Feb 03, 2010 | Vizio GV42L 42 in. LCD Television
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Older person cannot handle two remotes
You can program most satelite remotes to work on any device. Most are universal. If not, I suggest purchasing a universal remote. You can view remote codes online to program your device to your remote. New ones come with instrucions and codes.
Let me know how I can further assist you if necessary
Aug 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 32 in. LCD HDTV Logo
2,960 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
