Question about Epson Stylus CX6600 All-In-One InkJet Printer
No printing New ink, cleaned multiple times, used cleaning fluid inserted with syringe. Left over night. Still does not print. Sounds like everything is working.
  1. check your ink tube to the right of the ink cartridges....go thru "change ink" sequence but just move the spring loaded reservoir to the right to ensure the tub is connected in all places and will flow freely
  2. reset eprom by powering on w/"color" and "stop" buttons depressed...wait for flashing to stop...push "color"...power down...power up
Posted on Jul 15, 2009
My brother CIP-J140W is only printing in cyan. I had accidentally put the cyan cartridge in the black cartridge spcae. Despite changing them around, cleanre the head etc, it is still only printing in cyan....
Oops, You really have to print, selected black, till all Cyan ink is gone. This could take a while. Cleaning the head, won't solve anything.
If you really want to clean the ink out of the head and everything, you need special cleaning fluid. Refill shops do have this fluid. You should bring some cleaning fluid in the tube under the black cartridge, in the tube where the ink is going in. If you have a syringe you could try to gently press some fluid through the tube. Not to strong. could damage the head.
After placing back the black cartridge, select clean the head and let the printer do some black and withe print jobs, till the cyan is gone.
Nov 27, 2013 | Brother MultiFunction Center MFC-440CN...
My black ink cartridge ran out and it was 2 weeks before I replaced it-the old cartridge was still in the printer. Now with all new cartridges it will not print solid black-only a grey color instead of...
Hi Good day!!! if you try the head cleaning for 1 dozen of time and nothing has change, try this one method I'll give you, before you buy a new printer. all you need to have is a cleaning solution kit and a syringe.
1. remove the cartridge to expose the nozzle that feed the head
2. fill syringe with 2ml of your cleaning solution.
3. push end of tube over the nozzle that takes ink from the cartridge.
4.gently push the syringe allowing 1ml of cleaning solution to pass down the tube and into the head
5. leave the syringe in this position for couple of hours to allow the fluid to soak the dried ink particles.
6. after a couple of hours gentle push the rest of the fluid through the end
7. the next few prints may be contaminated with cleaning fluid and you are advised before carrying out any prints to do a full head clean using printer utility.
8. if after step 8 you still have a problem you can repeat the operation up to step 6, but instead of pushing the fluid through the head draw the fluid back into the syringe, and then back to the head, this causes fluid to move backward and forward in the head assembly, you should notice air bubbles and very small dried ink particles whist doing this. Please note while this product will remove stubborn dried ink particles it will not damage print head.
Don't forget to vote thanks!!!!
Nov 02, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
Print head is mising
PART B - RECOVERY/FLUSH PROCEDURE
1. GENTLY INJECT RED FLUID: Remove the CAP assembly (If not already removed). Place a paper towel in the
cavity where the cap was. Position the printhead over the towel. Remove any ink cartridges. Using a syringe with
tubing, gently Inject red cleaning fluid into each color and black nozzle set. (NOTE: If fluid can not be injected,
install and puddle cap with fluid and let soak for 30 minutes. Retry step 1.)
2. REPLACE THE CAP and RE-INSTALL THE OLD INK CARTRIDGES: Move the CR assembly to the left and
remove the paper towel, dab the area dry with a clean towel. Replace the CAP assembly and reconnect tubes.
3. PUDDLE THE CAP: Fill the cap with red fluid. That is, “puddle” the cap using the syringe.
4. SOAK OVERNIGHT: The printer is now ready to soak. The cartridges in place will keep the fluid in the head, and
the red fluid in the cap will loosen any remaining residual ink.
Leave undisturbed overnight
5. REMOVE THE CAP AND CLEAN: (Yes.. take out the cap and clean it again, just like Part A)
6. GENTLY INJECT CLEAR FLUID: Place a paper towel in the cavity where the cap was. Position the printhead over
the towel. Remove any ink cartridges. Using a syringe with tubing, gently Inject one full syringe of clear cleaning fluid
into each color and black nozzle set (flushing out the red fluid).
7. REINSTALL CAP: Put the CAP assembly back in.
8. WITH POWER ON, INSTALL NEW CARTRIDGES: Place new ink cartridges in the printer using the correct install
procedure.
9. PERFORM CLEANING CYCLES UNITL FRESH INK IS IN THE CAP: It usually takes two to three cleaning cycles until
the cap is “ banded” with color from the ink.
Jul 09, 2009 | Office Equipment & Supplies
New ink in printer but will not put ink on paper.
It sounds like blocked nozzles to me, providing you're SURE you have good cartridges, properly installed (you did take the yellow plastic tapes off the vents before you installed the cartridges of course).
You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results
Mar 07, 2009 | Epson Stylus C84 InkJet Printer
C86 Goes through printing process but nothing prints.
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper now after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat the head cleaning. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Proceed as follows:
Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move by hand. Move it out of the way to the left. On the right you should see the print head parking area. There is a rubber cup that is designed to fit under the print head to keep the ink from drying out. Using a syringe or dropper, fill this cup with print head cleaning fluid. Then gently move the print head as far as it will go to the right. The print nozzles are now bathed in print head cleaner. Leave it for at least 24 hours, then repeat the cleaning cycle process.
Jan 28, 2009 | Epson Stylus C86 InkJet Printer
I have epson i was given i have just put new ink in and it prints but with no ink
Have you carried out 2 or 3 head cleaning cycles? If not, do it. Is there ink on paper after this cleaning? If so, but it is streaky, leave the printer for 24 hours and repeat. If not, you must soak the heads for at least 24 hours - use print head cleaning fluid or distilled water NOT TAP WATER. Turn the printer on, and as soon as the print head moves, pull the power cord out of the back, or switch it off at the mains. You should now be able to move the print head over to the left by hand out of the way. Now look in the "parking bay" at the right end where the print head parks itself. You will see a small oval rubber cup that covers the print head when it is parked. Use a syringe or dropper to fill the cup with cleaning fluid, then gently push the print head as far into the parking position as it will go. Then leave for at least 24 hours. Then try the cleaning cycles again. If no joy after this, report.
Dec 13, 2008 | Epson C64 InkJet Printer
Black ink not working
Have you carried out any head cleaning cycles. If not, do it, then a nozzle check. Any sign of ink? If so do a couple more nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat. If you already have done lots of head cleans with no result, and you're sure you have a good ink cartridge in, then you can try soaking the print heads for 24 hours (or more), as follows.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Aug 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
Canon i550 doesn't print correctly
---Is the incrustation of the heads or the ducts such that I need to throw the i550 away
This one...
I had 3 Canon i550 and i560 printer, unfortunately if you use non original inks and leave the print head with no ink cartridge for some hours the ink can dry inside the print head = dead.
I have try several methods of cleaning print head and waste a lot of time on this, finally here some suggestions:
- use pure alchool (at least 90 °) to clean the print head, you can also use clear water but after you had to rinse with alchool because alchool removes the left water that can cause shortcircuit when you power on the print head.
- the electrical connections of the print head (brown ribbon with integrated circuit path) are very fragile if you decide to unmount the print head removing the 2 phlilips screws you must be VERY careful
- for black ,one safe trick is to remove the round (8 mm) glued upper metal sheet filter on the upper part of the print head where the ink cartridge sets. Once removed you can use a syringe needle filled with alchool to remove the dry ink and spray alchool into the small duct hole to remove all the bad dry ink. Be patien it will take some time. You can also leave the syringe filled wyth alchool and without the syringe piston for a night inside the duct hole.
Take a look to the service manual also for other inspirations:
http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
Nov 11, 2007 | Canon BubbleJet i550 InkJet Printer
RX500 not printing two ink colors
The problem is that air has got into the spike where the carts would normally sit and dried the ink in the head. This will be very difficult to soften and will take much perseverance on your part.
Get a syringe and some ammoniated cleaning solution or cartridge flush. You get cartridge flush off ebay - I use the JR brand, but that is my personal preference.
Remove the ink cartridges. Take some kitchen paper and fold it up so you can lay it in the bottom of the cartridge carrier leaving the wicks (The spikes upon which the cartridges sit) accessible.
Take the syringe and fill it with the cleaning solution. With a torch look closely and notice the small holes in the top of the wicks. You are going to flush out these wicks with your cleaning solution and the needle of your syringe.
Push the needle of the syringe into the hole of the wick. DO NOT APPLY ANY PRESSURE when inserting the needle. Use no more than the weight of the loaded syringe. Once inserted, SLOWLY depress the plunger of the syringe to ejecta few ML's into the wick. Do this for each wick and then leave the machine for at least an hour.
Repeat this several times replacing the kitchen paper each time you do it. When the cleaning solution starts to run clean you can start to eject the fluid with a little more speed to wash it further into the head. Again leave for an hour each time. Once you are sure you have dissolved as much ink as  you are ever going to, you should proceed to do an intensive under head cleaning as per my previous post HERE. Also put a good amount of cleaning solution into the pump cap (the bit under the head when it is in the park position) and top it up as it seeps away.
Once that is complete and you are again sure you will not get it any cleaner, get a full set of brand new and GENUINE cartridges. DO NOT be tempted to use cheap compatible cartridges for this maintenance exercise. Put the new carts in and allow the machine to charge the ink. Keep an eye on the pump cap and keep topping it up with cleaning solution. If the solution does not get sucked out of the pump cap, then you have a further problem and you should let me know here so I can help you sort that.
Print a nozzle check and see how it looks. If it still shows some gaps, run a couple of cleaning cycles via the button panel and print another check pattern. If there is little improvement after a couple of cleaning cycles do another manual under head cleaning.
You will eventually get the print back. For future reference, if you are leaving the machine unused for a while - leave it with full genuine ink carts. The genuine carts have an anti coagulant that helps to stop the ink solidifying in the head.
Let me know how you get on
Oct 17, 2007 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
