Question about Dryers
Will the cycling thermostat prevent the motor from firing up on a mde6400ayw maytag dryer.replaced everything else.
  • 52 Answers
There is a switch on a maytag motor. It may be bad.
Posted on Jul 14, 2009
Maytag Dryer MDE6400AYW. Dries clothing but does not shut off in Auto Mode. Tried Timer mode but the knob does not advance on its own and dryer does not shut off in that mode either. Replace Timer?
Some of them timer can be oiled, (just a little zoom oil no wd-40) if it is real hard to turn, the knob can become cracked and the timer motor itself it may not have enough ump to move the gears and sometimes oiling the timer and moving it around many times loosens em up.
Jan 11, 2017 | Maytag Dryers
Do you have a map/guide showing how to put a Maytag dryer timer/start motor back together model#mde6400ayw?
http://www.youtube.com/watch?v=3R8L8ho0gqQThat's a link to a you tube video. You can try and google for it if that doesn't help
Oct 08, 2012 | Dryers
Dryer won't start
This usually caused by a blown thermal fuse on the blower housing located behind the rear access panel. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Unplug the dryer or disconnect power then remove the rear access panel. Locate the thermal fuse then bypass it for troubleshooting purposes.
Bypass the thermal fuse by disconnecting the wires and joining it together. Insulate properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Clean the lint filter and make sure the vent system is not restricted then replace the thermal fuse including the cycling thermostat (thermistor for other models) as a standard operating procedure and preventive measure. The thermal fuse usually cuts out due to a failed cycling thermostat(thermistor for other models).
Jul 19, 2011 | Roper REX3614KW Electric Dryer
I have a Maytag SDG3606AWW Gas Dryer that is working but not drying the clothes. I have replaced the fuse, cycling thermostat on the blower motor. The gas flames is firing through the tube, goes on full...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jun 13, 2011 | Maytag SDG3606A Gas Dryer
Why would my dryer not be heating?
Most likely the heating element. But look for blockages that could cause safety's to trip before purchasing expensive heating elements is what I always say. To prevent fires dryers have a series of limits wired into the harness to shut down the element in case the dryer over heats. Maytag blowers are made of plastic and often are a cause of overheating. The clothes take much longer to dry if a blower wheel is to blame, so check that too. themobilian_94.jpgthemobilian_95.jpgthemobilian_96.jpgthemobilian_97.jpgGive me your model number and I will be more specific. Not all maytags are the same.
Nov 10, 2010 | Maytag Dryers
My Dryer Maytag PYE2300AYW is dead
HI. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Concerning the Control Thermostat(53-2880). This is the main control thermostat. if it is covered in lint as you have sated, this will confirm thermostat failure. this has tripped the thermal fuse in this case, totally rendering the dryer inoperable at this time. you will need to replace the Control thermostat and thermal fuse as well. this will fix your unit.
The thermal fuse can be tested be using a basic voltage needle but, it is really not needed. the thermostat has failed. the over cover of lint has shorted the device(lint will create an arch that will ruin the device)
Once the thermostat failed, the heat will rise to a unacceptable rate and, this will trip the thermal fuse and kill the dryer. its a safety feature to prevent a fire in your home.
Jul 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag model MDE9206AYW will not heat. Checked coil, fuses and limits and am now trying to check cycling thermister. Can you tell me how? also do you have any suggestions. suspect dryer went out during...
My generic wiring diagram doesn't show this dryer uses a thermistor, only thermostats. The difference is a thermistor has to have an electronic control to interpret the values the thermistor is sending. A thermostat is mechanical and only open or closes at a preengineered temperature. You would need to check the ohm readings of a thermistor at different temperatures to test it, but you only need to know continuity or no continuity to test a thermostat. First make sure you have 240 volts to the dryer, the heater is the only part that needs 240 to run. It's possible for only half of the breaker to trip and give the dryer only 120 volts, in this case everything but the heater would run. If you've got 240 volts, to the dryer, unplug it, then check for continuity between the 2 terminals of the 2 thermal fuses, cycling thermostat, and hi limit thermostat and heater. Remember you must disconnect one wire before testing to prevent incorrect readings. If it still runs, just no heat, the 2 thermal fuses should be ok, but check them anyways. If they all test ok you'll need to check the temp selector switch. You'll need the wiring diagram to show which terminals to check at each heat setting. If that checks out you'll need to move to the timer, again you'll need the diagram. If the timer checks, the only thing left is the centifugal switch in the motor, and the only way to check that is to test it with the motor running.
Jul 18, 2008 | Maytag Dryers
Dryers Logo
270 people viewed this question
Top Dryers Experts
