Question about Garmin EDGE 705
Cadence does not register on edge 705
My cadence does not register on edge 705. I replaced the battery, still nothing. Checked the alignment, too.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
This is probably a pairing problem. Device and cadence should be paired. Pairing is often lost when changing battery.
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Posted on Sep 25, 2010
My Edge 705 unit will not recognize the DSC 10 cadence sensor. Had one, thought the battery had died, changed that, this didn't work so I guessed the unit died and bought another one...same problem. Help!
When changing battery, accessories need to be paired again.
For pairing please follow instructions in manual or go to site http://www8.garmin.com/manuals/2297_OwnersManual.pdf
Aug 15, 2010 | Garmin Edge 705 Handheld GPS Receiver
There is no "climb data", elevation gain when I download to Ascent software.
Hello. you may need to go to garmin.com/drivers and download a new driver into your computer before you use that software again. Joe
Mar 22, 2010 | Cadence Garmin Edge 705 Bundle [heart,...
How to use garmin edge 705 cadence/speed sensor
you must disable the gps speed and enable the sensor
Feb 02, 2010 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
I used my 705 on my trainer and it did not record distance or speed like my forerunner does. The 705 works fine on the road
the Garmin Edge series rely on GPS to track your location from point A to point B thereby calculating your speed and distance. Its no different from any other GPS unit which require a clear view of the sky. It does not sense wheel movement, so using any GPS on a trainer will show no movement and using it indoors will give you a bad signal. The sensor on the crank used on the Edge 705 is only for cadence and not speed.
Jul 16, 2009 | Garmin Edge 705 Handheld GPS Receiver
I have installed my Garmin Edge Cadense Sensor, followed the instructions and seems like both the crank arm and wheel sensors are ticking and sensing. However, the edge does not seem to receive the...
There are two tests
705 first - settings, ANT+sport, accessories, check that cadence sensor is set to YES
press the reset on the cadence sensor and rotate the cranks - the LEDs should flash every time the magnet passes the sensor. if not its the position of the magent relative to the sensor that needs adjusting.
Hope that works
Jul 11, 2009 | Cadence Garmin Edge 705 Bundle W/spd Hrm...
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
The cadence sensor will not sink to my edge 705
Please perform pairing as described in you user's manual. Device must be paired before becoming available.
http://www8.garmin.com/products/manual.jsp?product=010-00555-20
Apr 05, 2009 | Garmin EDGE 705
I just bought the Edge 705 with heart rate. I have done everything to get the display of heart rate to come up on the screen but nothing is working. I've tried wetting the sensor on the strap, standing...
Menu>Settings>Data Fields>Bike Computer #>Press Stick>Select Field where you want HR to Display>Press Center Stick>Scroll to HR>Press Center Stick to select. et voila.
Mar 24, 2009 | Cadence Garmin Edge 705 With Speed And...
Garmin Edge 305/GSC10 Cadence and speed sensor
Had the same problem. Here is how I fixed it.
1. Changed the battery in the cadence sensor. (GSC10)
2. Turned on my garmin 305 edge outside to acquire satellites (probably not nec but did it anyway)
3. Pressed reset on the GSC10, saw red/green flash (what order?)
4. Here's the missing step: On the Edge unit, go to SYSTEM.
5. Scroll to bottom, choose ACCESSORIES.
6. On acc. page, go to bottom, under Cadence Sensor, to the option RESTART SCAN. Press That. Now your cadence and speed should work.
Feb 23, 2008 | Garmin Edge 305 GPS Receiver
Garmin EDGE 705 Logo
590 people viewed this question
Top Garmin Cycling Experts
SHARCNET-USA
SHARCNET-USA
perdue40
Are you a Garmin Cycling Expert? Answer questions, earn points and help others
