Question about Victor 1570-5 Calculator
1570-05 not working
None of the keys are responding, sometimes L-08 appears on the display
  • 682 Answers
One of your keys stuck inside try to push all keys with your hand many times bring a good brand contact cleaner from (radio shack) or another electronic store and spray above all the keys while you are pressing the keys many times.(use dry contact cleaner)
Posted on Mar 10, 2008
Only blue light with blank display on power on
Dear Joseph,
I had similar problem with my DGX620. In my case the display sometimes got blue and sometimes worked fine. The cause was a bad contact of the display flat cable.
I opened the DGX620 and then I cut a small piece of plastic film (35mm negative) with exactly the same width of the flat, disconnect the flat cable and then reconnected it using the film on the other side (non contact side) to increase the pressure and guarantee a good contact. No more problems from nov-2012 till now.
Good luck !
Paulo de Tarso (Brazil)
Nov 14, 2012 | Yamaha DGX630 - Digital Piano
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Feb 08, 2012 | Panasonic KX-FL501 Plain Paper Laser Fax
The calculator appears to be frozen; none of the buttons respond; the display only shows "Ans" with a little 2 above and to the right of it, making it look like Ans is squared and then a blinking cursor
If pressing CLEAR doesn't get rid of it, try resetting the calculator. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries.
Sep 09, 2010 | Texas Instruments TI-84 Plus Calculator
Display driver stops responding on Inspiron 1525
Try to clean memory modules on the bottom side of you notebook by alcogol and fabrics . Install antivirus programm.
Mar 07, 2009 | Dell Inspiron 1525 Notebook
Olymp. DS-330,None of the Buttons respond at all,only hold slider
If you remove the batteries and reinstall, does the display indicate Hold at some point? The hold button sometimes breakes and doesn't activate the switch. Pop off the hold button and move the internal switch manually.
Nov 21, 2008 | VXI Corporation VTR-3200 Handheld Digital...
Keys not working
The following table shows the possible reasons for performing a hard reset on a BlackBerry device Keypad is not functioning correctly. For example, keys do not work, the trackwheel is not functioning correctly, or the handheld does not turn on. Handheld display is hard to read. For example, the display shows lines obscuring text. To perform a hard reset on BlackBerry smartphones
  1. Remove the battery cover.
  2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
  3. Replace the battery cover.
Sep 22, 2008 | RIM BlackBerry Pearl 8100
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Keyboard not responding
Have you tried uninstalling and then re-installing the driver program for the keyboard?
Sep 12, 2005 | HP Jornada 720 Pocket PC
Victor 1570-5 Calculator Logo
88 people viewed this question
Top Victor Office Equipment & Supplies Experts
David Burbee
David Burbee
Greg Cann
Greg Cann
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
