Question about Boating
Engine cuts out when thortle is pushed foward. 1996
Engine cuts out when thortle is pushed foward 1996
  • 77 Answers
High speed jet in carb is clogged, thats why its fuel starving under a load. 99.9 percent sure a carb cleaning will fix your problems.
Posted on Jul 27, 2009
Nissan largo
Did you have it scanned for codes? If codes come up follow the diagnostic sequence. Cam or crank sensor may cause this, but I would get it scanned!
May 31, 2014 | 1996 Nissan Pathfinder
Where do i fill the rear wiper resevoire?
i do believe the same reservoir as the front wipers the line may b empty just push foward on the wiper switch for a few and give it time to get back there
Jan 22, 2011 | 1996 Jeep Grand Cherokee
Chevy 1500 1996 won't go
transmission gone bad or low fluid if leaking,you still need to know what the code means ,does the check engine light is on,but doesn't seem to be the engine.
Feb 25, 2010 | 1996 Chevrolet K1500
Need a 1996 1500 chevy 305 EXPERT!!!! ONLY!!!
Take an analog ohmmeter, remove connector from TP sensor, and touch probes on terminals of sensor, try combination of 2 until you see reading increase as gas pedal pushed & decrease as pedal released by someone, while engine off, and key off.. Have them slowly, & gradually push pedal, as you watch meter. Reading should increase slowly & gradually as well. If you see it climbing, then quickly drop off, then jump back up, it's faulty. Try to concentrate more on the position of gas pedal where you experience the engine cutting out. Costs nothing to try it.
Oct 16, 2009 | 1996 Chevrolet K1500
2 vacum lines coming down right side of frame from engine comp. cross over trans and go where?
is this a 4x4 ? if yes they go to the vacume switch screwed in to the left side of the transfer case faceing foward
Mar 22, 2009 | 1996 Dodge Ram 2500 Club Cab
Fuel filter
"Under the vehicle drivers side on the frame rail under the driver side door. There is frame right underneath it but you can access it easily. Be sure to release the fuel pressure before changing the filter. The fuel pressure release valve is located in the engine compartment on top of the engine. It is on the left side of the air intake manifold. It is just a small cap over the valve. Be sure not to lose that cap!! When you change the filter, the filter line on each side of the fuel filter has a quick disconnect type fitting inside the line (similar in principle to a quick disconnect on a gas line or air compressor line). To free the filter from the line you must push in (toward the filter) with a simple tool you can purchase at most auto parts stores for just a few dollars.
Additional Information The tool I was able to rent from NAPA. The guys there were very good to me. Look for about 45 min. of time to complete replacement.
While first off your going to need to relieve the pressure in the system, and if you think your going to just pull the fuel pump relay and then run the engine until it stops to relieve pressure it aint gonna work. Get a bleeder gauge. Your also gonna need a quick disconnect tool. Ford models are usually 1/4" 3/8" or 15/16". Put it on the fuel pump right before the "duck bill" then try to push the line foward. If that doesn't work just try to push the tool into the duck bill then try to push the line foward."
From WikiAnswers - Where is the fuel filter
Mar 01, 2009 | 1996 Ford Explorer
Rough idel , cuts out while in drive , stalls ,engine skip
Take the car to a garage that has a computer. I had the same problem and it turned out to be the idler solenoid that is located on top of the engine on the fuel injector port. The computer will diagnose the problem in a short time.
Jan 21, 2009 | 1994 Buick LeSabre
Driver side car seat
The seat may be too far forward, and when it is at the forward limits, the seat sticks. I get in the seat, and I press the back button whilst pushing hard with my feet against the floor.
Aug 14, 2008 | 1996 Toyota Avalon
Boating Logo
102 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
