An Fedders mod# WFB1002 air handler has been hit by lightning and the fan runs constantly. Where can i find the part 052310 to fix it?
  • 614 Answers
You can buy this part online at any ac parts website. You can replace it witha double pole double throw 24 volts realy. Rus
Posted on Jul 15, 2009
I want to fix my split system ac.
You are referring to the air handler portion of AC. One of the fan blades is hitting something. Kill the power to all of ac and air handler and open up the air handler by removing the panel facing you exposing the fan. Manually turn the blade and look for the offender. Bend back into place, put back panel and tape up properly and turn all breakers back on.
Ir maybe just moving the fan motor itself slightly will do the trick. Whatever is easier and works will do.
Sep 08, 2015 | Heating & Cooling
How do I fix my Trane air handler to keep it from turning off about 20 seconds after being commanded to turn on?
Some units require both a start and a run capacitor. It's possible the wrong capacitor was replaced. It's also possible to add a run capacitor to a system to keep the fan running. There is an outside chance the bearings in the fan motor are worn to the point it's time to replace the motor.
Mar 29, 2015 | Heating & Cooling
Air conditioner fan is blowing but not air coming
If you mean that your OUTDOOR AIR CONDITIONER FAN MOTOR is blowing AND no air is coming out of the vents within your house, it clearly indicates to me that 1 of 2 things are wrong.
Either (1) your INDOOR AIR HANDLER is NOT running or (2) the INDOOR AIR HANDLER is running but your PLENUM has come apart.
If your INDOOR AIR HANDLER UNIT is NOT running, it could simply be the circuit breaker is OFF/TRIPPED and simply needs to be turned OFF; then turned ON. If that does not FIX your problem, then it is most likely your 5 micro-farad run capacitor for your indoor fan motor needs to be replaced. It will prevent your indoor fan motor from energizing. Worst case scenario would be your INDOOR FAN MOTOR has windings burnt and needs to be replaced. If your indoor air handling unit is equipped with a CONDENSATE VALVE CUT-OFF SWITCH, check to see if your drain pan is filled, thus energizing the switch. If the CONDENSATE VALVE CUT-OFF SWITCH is ENERGIZED, it will prevent the AIR HANDLER FROM energizing. That is the design and the reason for this valve.
Good luck.
Aug 26, 2014 | Heating & Cooling
I have a Bryant Model 340MAV and the airconditioning fan is loud when running but seems to operating fine otherwise..fan is running and cooling great..the oustide coil was replaced in April. Please advise
Sounds like the motor is going bad in the air handler/furnace now...
Open up the blower compartment and spin the blower by hand with the power off...you should be able to hear if the bearings are rough or if the blower is hitting something... then you will know what you need to fix...
heatman101
Aug 29, 2011 | Heating & Cooling
AC 'squeak'
inside fan blade could be hitting styrofom houseing
Aug 27, 2009 | Fedders A6Y12F2D Thru-Wall/Window Air...
My A/C is turned OFF, but the Air handler is running. How can I fix this???
You need to check your thermostat setting to see if the fan setting is in the always on setting instead of auto setting as this would cause the air handler to constantly run. Hope this helps.
Jul 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Help
Old rheems ahd a reeset for head pressure on outside unit. May have took out the transformer. Check inside Air handler to see if there is five amp auto fuse in the fan board it may have blown. Rus
Jun 14, 2009 | Ruud Matching Split Air Conditioner
Constantly running
follow the wires from compressor to contactor or relay contacts stuck replace
May 24, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
