Question about Amana Heating & Cooling
Water running through overflow
Yesterday was the first time my airconditionar ran this year. I noticed last night water was draining from the overflow. The unit is in the attic and the drain runs out the side of the attic. should I be concerned?
  • 2,418 Answers
No, Do you mean that water is draining outside when it is running, if so, no need to be concerned. Yes yes yes be concerned if it is draining on to the ceiling.Get up there and ck the drain make sure the pan is tilted right to drain. ck the drain out side make sure it is free to flow. .
Posted on Jul 14, 2009
What causes yellow gunk in the oil cap on my 2004 chevy trailblazer
Could be a leaking head gasket or intake gasket.
The gunk is water or coolant. Water if the engine never warms up, coolant if there is a leak.
Mar 06, 2013 | 2004 Chevrolet TrailBlazer
My 1999 toyota camry has had a large puddle under it last 3 days. I got a new radiator installed last year. i filled the overflow w antifreeze yesterday, it drained out, in a couple of hrs. i filled w...
look close on the top of the radiator they crack there. and the other thing you can do is put a piece of card board under the front and run the car and see where it leaks
Dec 04, 2012 | Toyota Camry Cars & Trucks
My Kenmore moel #11027082602 ran while we were
Yes it is very possible. If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Feb 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My Whirlpool Cabrio washer is backing up into and overflowing my toilet every once in a while during the spin cylce. But today, the washer was not running and the toilet overflowed. The toilet is located...
Your problem is not with the washing machine. I suspect that the drain line for your toilet is obstructed further down the line than your snake can reach. If you have a clean out riser to your sewer system, flush the toilet while someone else is watching the flow past the clean out. I would say that renting a sewer line snake at a tool rental like Home Depot would solve your problem. Good luck
Mar 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Problem with KitchenAid KUIA18PNLS0 Under-Counter 18-inch Ice Mak
There is no solution. I have three kitchenaid ice makers and they do not work. The 18inch was under warranty. I had it serviced every friday until warranty ran out. I put an inline filter on the machine and it ran like a charm for three months, which is a first. It's out again! The two 15 inch same thing... inline filter and it worked for a month. Yes I have cleaned the machine over and over with appropriate products. It will turn on water fills but it appears as though the pump is not moving the water. Either way the machine worked correctly for two years only for the 15 inch and for the 18 inch one year.
Jul 15, 2009 | Kitchen Appliances - Others
A/C Clogged drain pipe
Can you get to the hose in the house unit? If so canned air
May 26, 2009 | Carrier Heating & Cooling
No water coming into machine. Programme not running because the machine is still trying to fill. If I add water the machine does drain. Was cleaned with a good dishwasher cleaner only last week. Nothing to...
Turns out that the dishwasher had a leak in the bottom. No water could be seen leaking out because Bosch machines have a cut-off valve that means if a tray in the bottom of the machine fills up with water, the float valve doesn't allow anymore water into the machine. we worked this out after we tipped the machine slightly, water ran out, when we put it back down and started it the inlet valve worked until the bottom had filled with water again.
New machine for us! However, not a critism of Bosch. We use our machine at least two or three times a day and have done for the last 5 years.
Sep 09, 2008 | Dishwashers
GE washing machine water overflowing
sound like the same washing machine from hell that we have. three or four times it has overflowed from want we have been told the hose that runs from the drum to on/off pressure switch cloggeds with soap. we have tried different soap,hot water,cold,water you name it we've tried it. so now evey time we use it we have to clean it with a coat hanger by taking the front off the machine.
P.S. take the hose off top and bottom to clean it, all it takes two/three very small soap bubbles to clogged it
Oct 28, 2007 | Washing Machines
Heating & Cooling Logo
167 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
