Re: Head lights dim and lose power steering when at low...
The most common cause of these problems is a loose slipping fan belt. For most cars the belt is held tight by a tension-er. This is a pulley that is spring loaded. Usually the tension-er applies the force to the back side of the belt. Tension-er has been known to stick and not flex with the belt allowing the belt to slip. Also if the belt is worn it can slip. Another possibility is that one of the accessories, on the belt circuit are having trouble rotating prohibiting the belt to operate freely. Careful inspection of the belt will determine its condition. With the hood open listen to the motor at idle and the sound of a squeaking belt is an indication that the belt is slipping. To test for the tension-er with the engine off try tapping in the direction of tightening the belt on the tension-er with a rubber mallet. Start the engine and observe if the condition is still the same. If it has corrected the problem than the tension-er either needs to be cleaned or replaced.
Testimonial: "i put new belt on and new tensoner on not long ago"
the pump may have locked up,try turning it with the belt off,since its off now,which is why the battery light came on and lost power.Anyhow turn it back and forth feel for end shaft play,drain about 1 pint of fluid out by using a turkey baster, and add 1 pint of dot 3 brake fluid to the powersteering fluid,it helps with lubricating the bearings and seals.
they all are wrong .i was a service tech for Cadillac for 15 year and guarantee you that the problem is in you're crank shaft sensor .Cadillac redesign the sensor on 2002.check for code you'll find p0355 and p0385 .replace the sensor and reprogram the new ones.good luck Danny.B
#1: Panel Illumination
#2: Guages,Right High beam headlight and the high beam indicator
#3: Rear Wiper, Left headlight High Beam
#4: RH park, backup lights switch and relay,Speed porpotional steering module,power door lock switch illumination and daytime running lights(Canada)
#5: Power Door locks,Power Mirrors,vanity,dome,map,ignition and trunk lights,sunroof,radio,power antenna,body control module and power for the data link connector
#6:Heated mirrors,heated rear window indicator
#7: Instrument cluster illumination,park and tail lights
#8: Cigarette lighter,Radio Amp and horns
#9: Power door lock motors
#10: Not used
#11: Radio
#12:Left low beam head light
#13,14,15,16 not used
well I can't drive it and see all symptoms.
i can't see the idle speed drop below 800 RPM,. !
if the idle drops real low, then engine shakes, and PS gets weaker.
Id ignore the EPS till such time as all other things are perfect.
ever get an engine tuneup this decade?
low engine RPM , top number 1 cause is owners not servicing their cars. (spark plugs bad tops that list)
if you ignore that, tuneup the engine WILL misfire and RPM will drop and P/s (means power steering)will get weak (the assist is pump driven) and then the engine can stall.
i bet you also forgot to say the steering got weak
park or coming to a stop with foot off throttle.
do the head lights dim as this (bad) happens?
can you use your right foot to keep RPM above 800 and save stalls or near stalls?
IF RPM is ok, ?then check the fan belt next. (slips)
or buy a new on, my guess is 11 year old belt is kinda hopeless case.
Which insturment cluster does your's have ? electronic instrument cluster or standard instrument cluster !
Standard insturment cluster - speedo / odometer Speedometer/Odometer
The speedometer and odometer provides speed information based on a speed/distance pulse signal from the vehicle speed sensor (VSS). The VSS is mounted on the speedometer driven gear in the transmission.
Could be the VSS is bad .
Horn
The horn system includes the following:
horn relay
horn
clock spring
steering wheel control switch harness
steering wheel pad horn switch, which is part of the driver side air bag module. For additional information, refer to Section 501-20B .
The horn is located behind the front bumper mounted to the radiator support.
Is the air bag light lit on the insturment cluster ? If it is the clock spring could be the problem . If not lit check the circuits from the horn relay .
Which headlamps don't work ? Low beams , high beams , both ?
The high beams are inoperative
Bulbs.
Circuitry.
Multifunction switch.
GO to Pinpoint Test C .
The low beams are inoperative
Bulbs.
Circuitry.
Headlamp switch.
LCM.
GO to Pinpoint Test D .
Principles of Operation NOTE: Due to varying wattage ratings and resulting current draw, certain aftermarket headlamp bulbs may cause the lighting control module (LCM) to shut down the short circuit protection, resulting in the low beams becoming inoperative. Verify that the headlamp bulbs meet Ford specifications.
Headlamp System
The headlamp system consists of:
two aerodynamic halogen headlamp bulbs and retainers
headlamp switch
multifunction switch
circuit wiring and circuit protection
In normal operation:
With the multifunction switch in the low beam position, power is supplied by the LCM to the low beam elements through the multifunction switch.
With the multifunction switch in the high beam position (forward detent), power is supplied to the high beam elements and to the high beam indicator in the instrument cluster.
When the multifunction switch is pulled toward the steering wheel, the flash-to-pass switch (part of the multifunction switch) is closed and power is supplied to the high beam elements. When the switch is released, they return to low beam operation.
The battery saver feature of the LCM will automatically turn off the courtesy lamps, demand lamps, headlamps, or parking lamps under the following conditions:
The ignition switch is in the OFF position.
The headlamp switch is in parking lamps ON or headlamps ON positions.
After 10 minutes.
Headlamp Switch
The headlamp switch is a multi-position switch.
The positions include OFF, PARK, and HEAD.
With the headlamp switch in the PARK position (first detent), a signal is supplied to the LCM which powers the front parking lamps, the tail lamps, the side marker lamps, and the license lamp.
With the headlamp switch in the HEAD position, power is supplied to the headlamps through the LCM and the multifunction switch.
The panel dim switch (part of the headlamp switch) is located above the headlamp switch. The panel dim switch operates only with the parking lamps or headlamps on.
When the panel dim switch is held in the up position, the instrument panel lighting will progressively brighten.
When the panel dim switch is held in the down position, the instrument panel lighting will progressively dim.
For additional information, refer to Section 413-00 .
Headlamps On Warning Chime
If the headlamp switch is left in either the PARK or HEAD position and the driver door is opened, the LCM will sound a headlamps on reminder chime when the following conditions occur:
The ignition switch is OFF with the ignition key out.
The driver door is ajar.
For additional information, refer to Section 413-09 .
Inspection and Verification
Verify the customer concern by operating the system.
Visually inspect for obvious signs of mechanical and electrical damage.
try taking the vehicle out in the parking lot and cut the wheel to hard lock, apply light throttle and do circles to the left, stop cut the wheel to hard lock on the other side and repeat this three or four times, also you can apply throttle while in park and rotate steering wheel lock to lock many times, the explorers are known for having air trapped in lines,try this and let me know.
the Alternator (this keeps the battery charged) is not charging the battery, the lights dim due to the battery voltage dropping low, go to any Kragen or Autozone and have the battery and the Alternator/generator tested, it is free.
Are all of these not working ?
• Air temperature switch
• Cigar lighter lamp
• Door switches
• Driver information center (DIC) switch
• Headlamp switch
• Head-up display (HUD) switch
• Heated seat switches
• HVAC control assembly
• Instrument panel cluster (IPC)
• Memory function switch
• Radio
• Steering wheel controls
• Window switches
Interior Lamps Dimming
This group of interior lighting includes lamps which may be dimmed. This group uses a combination of class 2 controlled illumination and incandescent lamps:
• Door switches
• Headlamp switch
• Radio
• Window switches
For the interior lighting to be dimmed the following conditions must be met:
Here is a discription of how they work ,factory service info.
• A low light level has been detected by the dash integration module (DIM)
• Headlamp switch is placed in to the PARK or HEAD position
• Ignition switch is placed in the ON position
Then all class 2 displays and all incandescent back lighting will be illuminated to the level set by the instrument panel (I/P) dimmer switch. When the I/P dimmer switch is moved from MIN to MAX, all class 2 displays and all incandescent back lighting respond from minimum intensity to maximum brightness.
The DIM supplies battery positive voltage to the coil side of the PRK LP relay in the rear fuse block.
When the I/P dimmer switch is moved from MIN to MAX, then the instrument panel module (IPM), W/CJ2, or climate control panel (CCP), W/C67, applies a message to the class 2 communication circuit to the DIM. The DIM then applies a ground to the park lamp relay control circuit. This energizes the PRK LAMP relay and allows battery positive voltage to be applied through the DIMR fuse to the DIM. The DIM then illuminates the following incandescent lamps through the incandescent dimming output circuit:
• DIC Switch
• Headlamp switch
• HUD switch
• IPC
• Radio
The DIM also applies a message to the following class 2 controlled illumination components:
• Drivers door module (DDM)
• IPC
• Radio
The DDM will then send a message through the simple bus interface (SBI) to the RH front door module (RFDM). The door modules will then illuminate the following components through the incandescent dimming output circuit:
• Heated seat switches (W/KA1)
• Memory function switch (W/A45)
• Power door lock switches
• Power window switches
The ground for these components are provided from the DDM and RFDM.
The following components are grounded at G200:
• Headlamp switch
• Radio
The following components are grounded at G201:
• DIC Switch
• HUD switch
Having the vehicle checked for DTC'S - diagnostic trouble code's would probably be your best course of action .
DTC B2556 (1)
The I/P dimmer switch is a potentiometer. The instrument panel module (IPM) determines the control setting based on the voltage from the I/P dimmer switch. The IPM sends out a class 2 message to the dash integration module (DIM). The intensity of the interior backlighting shall be adjustable when ever the park lamps are on. The intensity of the vacuum florescent displays shall only be adjustable when it is night and the park lamps are active.
DTC B2627
DTC B2628
Circuit Description
The I/P dimmer switch is a potentiometer. It is powered by the HVAC control module. The HVAC control module determines the level of dimming desired based on the voltage from the I/P dimmer switch. The HVAC control module converts the I/P dimmer switch feed back voltage to a digital signal and puts it on the Class II communication bus.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Your best bet ,take your vehicle to a qualified repair shop.
