Question about Acer Aspire One A150-1672 Notebook
Laptop comes on to welcome then goes blank and wont go any further
Laptop gets stuck welcome screen
I recommend trying to start up through safe mode. Back up all your files then re-image the computer
Nov 30, 2013 | HP Computers & Internet
I have a Nokia 6500, and every tine i slide it up or down the screen goes blank, but if i slide it up half way up it works. please fix it
Hello and Welcome to FixYa!
The sliding mechanism of your mobile phone has a flexible paper like wire bundle called a wire strip. With time the wire strip becomes faulty and starts to have cracks in it. When this happens the display or the earpiece may not work. When you slide it up half way it works because the broken strip comes in contact for a moment. I will recommend you to take this phone to a Nokia service center. They will remove the faulty strip and insert a new one. They wont charge you much. If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Computers & Internet
Screen goes blank after afew second on ac inly
Try booting to the Safe Mode (F8 at boot) see if you get any further. Also, does the system complete boot (DO you hear windows sounds?) or is the system just hanging after the Splash screen (You can also try an external monitor and press Fn+F8 to enable the external display) If you can get video externally, then is it likely a LCD or video card failure. If you can't boot to the safe mode and you do not hear the Windows Welcome sound that normally plays at the desktop, then the system is not booting and you have either a hard drive failure and/or an operating system failure.
See if you can boot to the BIOS (F2 at boot), then reload the default settings and reboot.
If you suspect the OS is a problem, boot to the XP CD, then run CHKDSK /R and see if that helps
You can also run system Diagnostics by pressing Fn+the Power button
Dec 21, 2009 | Dell Latitude D800 Notebook
My Dell Inspiron laptop boot up freezes
RUN CHECK DISK AND IF IT STILL WONT BOOT RESTART AND BEFOR THE WINDOWS LOGO COMES ON PRESS F8 AND CHECK START IN SAFE MODE THEN RUN CHECK DISK
Nov 12, 2009 | Dell Inspiron 6400 Notebook
Satellite A135-S4427 PC Notebook wont start at all
it might be because your laptop is not able to complete post (power on self test), moreover have you tried holding the power button down for 15 sec without the battery and ac adapter and then trying to start
to troubleshoot further you should contact a local technician
Further Queries are welcome
Feb 20, 2009 | Toshiba Satellite A135-S4427 Notebook
Monitor goes in and out
do you mean to say that your system shuts down when you are not pressing the laptop ie, the power light also goes off when you are not applying the pressure, or just the monitor goes blank and power light is on when there is no pressure
in both the above cases i think you should call technical support for your laptop, because it seems like a hard ware problem
Dec 15, 2008 | Gateway Solo 5300 Notebook
Blank Screen
id say its hardware. try pulling the hard drive out and checking to see if posting gets any further.. it also could be the cd drive causing the post hang.
Dec 20, 2007 | Computers & Internet
Acer Aspire One A150-1672 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
